Old 01-02-2016, 07:59 PM   #1
Jayschevy
Whose using GPS Speedometers?
I have a few sets of wheels that I use throughout the year and a GPS speedometer would work great for me letting me know my speed regardless of the size wheels I'm using.
I'm thinking about getting one from Autometer or Speedhut and was wondering what everyone does with the location on the transmission where the speedo cable plugs into. Once I remove the mechanical speedo cable I'll need to put something in it's place.
Jayschevy is offline   Reply With Quote
Old 01-02-2016, 08:23 PM   #2
novapower
Re: Whose using GPS Speedometers?
I have two speedhut ones.the car has like a freeze plug in the hole. ( took the hole outside piece off ) and on my truck I put a large rubber boot over the out put.kind of like the small ones you have on a crab to plug vent holes up.
novapower is offline   Reply With Quote
Old 01-02-2016, 08:42 PM   #3
Jayschevy
The rubber boot may work. I have a TH350 transmission and I want to keep the "bullet" speedometer cable gear housing and plastic gear in it's normal place but just cover the hole.
Old 01-04-2016, 11:30 PM   #4
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Whose using GPS Speedometers?
I have the speed hut in mine also. Great speedo. I took a vacuum rubber plug I bought at O Reilly's and put over the mount on the transmission.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-05-2016, 02:51 PM   #5
Jayschevy
Thanks that's what I'm planning on doing.
