Old 01-04-2016, 05:07 PM   #76
cypressbog
Go Pack Go!
Re: Why are automatics more popular than manuals?
My knees are shot, but still enjoy the manual.
cypressbog is offline   Reply With Quote
Old 01-04-2016, 08:31 PM   #77
A clutch is a lot easier than walking
Old 01-05-2016, 01:08 AM   #78
jjzepplin
jjzepplin's Avatar
Cool Re: Why are automatics more popular than manuals?
I LOVE a good four speed-linkage adjusted right- nice and tight shifter- popping the clutch have way in and then jamming the throttle and getting 70 mile an hour scratch is just plain fun!
My 4x4 has a doubler that makes the granny gear in a 465 a pretty fast gear. Fourth gear with both cases in low I think it would red line at 15mph.
Never tried. Sure was nice going through the Rubicon.
My 700r4 in the 4x4 is quite built and has never failed me.
My 4 speed never did either.
No garage queens here.
Jamming gears is fun and I miss it.
But hauling across the states I drove my auto. Hmm-Like them both!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 01-05-2016, 10:02 AM   #79
collin70k/20
collin70k/20's Avatar
I'm changing the turbo 400 trans out of my 1970 k/20 truck to a four speed. I'm changing it cause I love driving stick and it would be better for towing and getting the Rpm higher while pulling a load.
collin70k/20 is offline   Reply With Quote
Old 01-05-2016, 01:39 PM   #80
kehstr
kehstr's Avatar
I personally love manuals, but so many people like to just get in their car put it in gear, and hit the gas. But once you learn how to drive a manual, you can't go back, it's just not as much fun as picking your gear, then controlling the slip of the clutch, you just have the control of everything that the trans does.
Automatics do have their place, if you build a rock crawler, you want an automatic so you can stomp on the throttle to get over those stuff climbs, mostly just depends on what the car is used for
kehstr is offline   Reply With Quote
Old 01-05-2016, 02:32 PM   #81
tommys72
tommys72's Avatar
More cars and traffic is a big part of it. A manual trans sucks in traffic
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 01-05-2016, 02:53 PM   #82
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Exactly. Imagine owning a manual transmission and commuting in a place like Seattle. It's inconvenient and you'll run through clutches.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 01-05-2016, 03:04 PM   #83
cleszkie
cleszkie's Avatar
I once watched a fully sponsored competition tube buggy burn to the ground while wheeling out at the Hammers in Johnson Valley, CA (not in my Blazer, but in my own rock buggy). The fully built TH400 auto overheated from severe use while the buggy was in a nose down position. The tranny fluid boiled up and out of the dipstick tube, which had a locking cap, and poured over the hot exhaust manifold. After trying to douse the flames with no less than seven fire extinguishers, the fire kept reigniting since the ATF continued to pour on the manifold. Ultimately, everyone had to just back away and let it burn. I'm pretty sure the 90w oil in my buggy's SM 465 wouldn't ignite like that, much less get hot enough to boil out! Not saying that auto trannys don't work great for wheeling, just saying that there are definitely some added risks.
cleszkie is offline   Reply With Quote
Old 01-05-2016, 03:33 PM   #84
marvgarr68
marvgarr68's Avatar
I like both worlds in one. It is a blast to have a manual valve body automatic. All else is manual after all I have 15 gears in my dually to go through.
1976 k20, 350 built, 44/14 axles
1968 c10 6.5 turbo diesel,t5 trans
1977 gmc c3500 dually, crew, 4-53t, 5&3 trans
http://67-72chevytrucks.com/vboard/s...d.php?t=591188
marvgarr68 is offline   Reply With Quote
Old 01-05-2016, 04:47 PM   #85
Bad70sbchevy
Bad70sbchevy's Avatar
I have to agree manuals are fun to drive, but the reason I have a TH400 in mine is automatics are generally faster/consistant at the strip plus not as violent on your drivetrain on launch if you are footbraking.
1970 Chevrolet C-10 w/355sbc
2010 Silverado Daily Driver
1971 Mercedes 280sl project car
Bad70sbchevy is offline   Reply With Quote
Old 01-05-2016, 08:18 PM   #86
If all cars were still manual you wouldn't have people driving too fast and not realizing it. You shift up a gear as you need in a manual, so you are conscious of your speed. In an automatic it is "ON" and they are going as fast as they can till something in front of them slows them down.People going down hill on Main St. 50 mph because they are in O/D in a 25 zone. 40 mph across the grocery store parking lot. In a manual I'm in second going 15-20 and when I let off the gas it slows right down. When you choose the gear you are in you aware of your speed. You decide to go faster and do what is needed to increase speed. YOU drive the car, not the car drives itself.
Old 01-05-2016, 08:41 PM   #87
92GMCDriver
92GMCDriver's Avatar
Its mostly personal preference, i used to daily drive a 2003 dodge cummins diesel with a 6 speed, that thing was amazing for towing but drive that thing around in traffic long enough and it would really wear on you. for all my toys i like to have manuals as i do agree it is a better driving experience but daily drivers i like an auto. when i get up in the morning to go to work at 6 am i like to be able to drink my coffee and just hammer down and go.
Cole.
1967 GMC c15
1991 k2500
2005 2500hd Duramax
92GMCDriver is offline   Reply With Quote
Old 01-05-2016, 11:41 PM   #88
'68 Newtricks
'68 Newtricks's Avatar
6 days a week and you'll understand
http://media2.govtech.com/images/770...os-angeles.jpg
'68 C10 SWB
'85 K30 Blazer
'68 Newtricks is offline   Reply With Quote
Old 01-06-2016, 12:23 AM   #89
Canuckvetter
How did I get this OLD!
Canuckvetter's Avatar
I am very fortunate to have 2-67 LWB. The vermillion truck is manual everything, 283, no radio, 3 on the tree, farm truck. The medium blue is CST, PS, PB, 350THM. I love to drive both truck and nice to be able to choose which one. Going to the cruise nights, power steering is nice for parking. Personal preference is the manual.
http://67-72chevytrucks.com/vboard/a...1&d=1452053047
Canuckvetter is offline   Reply With Quote
Old 01-06-2016, 01:30 AM   #90
71CHEVYSHORTBED402
Back in the day I drove a truck like this one below........on a ranch. I never paid much attention (my stepdads), but I'm pretty sure it was a straight 6, with an oiled air cleaner (not sure what called). Talk about a granny gear, we're talking 1 MPH before having to shift into 2nd.
It was cool. The "city boy" tending horses early in the morning on a 70 acre boarding ranch.....Busting up ice in horse troughs, bailing hay. I once got high centered, stepdad wasn't happy. I learned how to use jacks and blocks............fun. I have a special appreciation for horse manure......So did my sweet toy cocker spaniel, because she liked to roll in it. That dog was as smart as they come, and training to her was an insult. She understood the first time.
Old 01-06-2016, 08:11 AM   #91
hamjet
hamjet's Avatar
Where's everybody going????
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 01-06-2016, 02:26 PM   #92
cleszkie
cleszkie's Avatar
I guess we should all just be happy that we have a choice of which transmission we operate. From what I'm reading these days, autonomous cars are in our future, which will do ALL the driving for us while we sit on out thumbs in the back seat
Old 01-06-2016, 02:29 PM   #93
71CHEVYSHORTBED402
And we wonder why mental illnesses continue to climb.
Old 01-06-2016, 02:54 PM   #94
1972RedNeck
1972RedNeck's Avatar
Maybe in your future, but there ain't none in mine!
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 01-06-2016, 04:13 PM   #95
flashed
There wont be no self driving car in my future either unless its free .I like my old stuff just fine thankyou .
flashed is offline   Reply With Quote
Old 01-06-2016, 07:29 PM   #96
jeffahart
jeffahart's Avatar
Kind of a silly question, but let me answer.
Automatics were designed back when vehicles were still unreliable. What would happen is you would kick the vehicle in anger when it would not start... leaving only one good leg to drive... very hard shifting one legged with a manual stick. So, the automatic transmission was invented. Now when it doesn't start, you can kick the damn thing in anger. And still drive home safely while all greasy, dirty, bitter and angry from getting it started. And the sore leg is not an issue.
In closing... it's obvious..... Angry people drive automatics!!!
Next question!
White K20
jeffahart is offline   Reply With Quote
Old 01-07-2016, 12:34 AM   #97
71CHEVYSHORTBED402
Next question!
Makes perfect sense.
