Old 01-06-2016, 10:41 PM   #1
Aric91
Rear main seal 292
I'm driving a 1970 292 and my rear main seal starting leaking recently and I'm looking to replace soon. I've dropped my oil pan before and it is a pain in the rear having to lift the motor. Does anyone have any advice on if I can get the rear main changed by removing the oil pan bolts but not lifting the motor to fully remove the pan. Thank you
1972 292 c10
Aric91 is offline   Reply With Quote
Old 01-06-2016, 11:38 PM   #2
firedemon
Re: Rear main seal 292
you will never get the pan off without lifting the motor pain in the ***
firedemon is offline   Reply With Quote
Old 01-07-2016, 01:13 AM   #3
Aric91
Would I at least be able to lower it enough to have the clearance to get in there and pull the seal out
Old 01-07-2016, 03:11 AM   #4
'68OrangeSunshine
'68OrangeSunshine's Avatar
BTDT. You will have to loosen motor mounts and even free up one side, and jack up rear of block to get oil pan out for regasketing.
Yes it's a PIA.
'68OrangeSunshine is online now   Reply With Quote
Old 01-07-2016, 07:33 AM   #5
Grumpy old man
Grumpy old man's Avatar
For the amount of time you will spend laying on your back cursing ,cleaning the old gaskets off and replacing them it's just easier to spend a weekend and pull it out ,Change ALL the gaskets ,clean,repaint and reinstall and not take the chance of it leaking again .Sometimes it just pays to bite the bullet and GIT ER DONE
Old 01-07-2016, 12:38 PM   #6
RANDY COX
RANDY COX's Avatar
^^^^^^^^^^ yea what he said I'm going to have to do it to mine it's leaking at the front...
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 01-07-2016, 03:11 PM   #7
zeldman
zeldman's Avatar
Same thing I was going to suggest. It only takes an hour or so to get a 6 cyl out, and it is so much easier to get done right the first time. Plus the engine and engine compartment can be cleaned up, plus there might be other problems that could be attended to while the engine is out.
Get a couple friends, fire up the grill, stock up on favorite beverages and make a weekend out of it.
2005 GMC K2500HD D/A
1993 GMC K1500
2011 Subaru Legacy.
2013 Subaru Outback
1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot.
zeldman is offline   Reply With Quote
Old 01-07-2016, 06:30 PM   #8
GRX
GRX's Avatar
x3 on Grumpy's post. You are far better off pulling the engine & replacing all the gaskets, seals, AND freeze plugs.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
