Old 01-06-2016, 08:28 PM   #1
1966SWB
1962 chassis with 1966 sheet metal
Hello,
I understand the differences in the frame rails, front suspension and X member, but will the cab, fenders, bed and bumpers of a 66 fit on a 62 torsion bar frame?
1966SWB is offline   Reply With Quote
Old 01-06-2016, 10:06 PM   #2
DPowers
One foot in front of the other
DPowers's Avatar
Re: 1962 chassis with 1966 sheet metal
There is alot of good info in the FAQ section. If I remember right the bumper mounting maybe different?
DPowers is offline   Reply With Quote
Old 01-06-2016, 10:15 PM   #3
62stepside longbox
62stepside longbox's Avatar
I believe they have different front cab mounts. Also the bumpers will fit but the holes won't line up. If you really wanted to make the later bumpers work on the early frame you could weld the old holes shut and drill new ones then use a file to make them square.
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 01-06-2016, 10:20 PM   #4
padresag
Originally Posted by 1966SWB View Post
Hello,
why would you want to do that
bumpers.cab and box mounting are different and the frame nbrs will not match the cab vin nbr so you will have that to deal with. there is also you will have a problem installing manual clutch linkage as 60-62 used hydr. linkage mounted on passenger side
ron
padresag is offline   Reply With Quote
Old 01-07-2016, 12:05 AM   #5
1966SWB
It was just a thought. Not a very good one. Too many differences
Old 01-07-2016, 01:48 AM   #6
Captainfab
60-66 Nut
In the state of Idaho, having a frame and cab with different VIN's can be an issue unless you follow the state motor vehicle investigator's requirements. That can be both expensive and a pain in the butt.
