Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-03-2013, 05:06 PM   #1
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
PTFE vs Rubber line fittings
Help me out here guys, I've never even touched PTFE in a project before.
I decided to re-do some parts of my fuel system that had regular Fuel injection rubber line, since the NHRA rule doesn't seem to like that stuff
The rest of my system is mostly -6 AN braided stainless rubber-core line, and was assembled like I'm used to. But on ordering some new -8 AN stuff for part of the feed, I somehow ordered (or was sent) -8 PTFE. To make it more confusing, the two -8 fittings I ordered are from 2 manufacturers and look completely different.
Fitting #1 they sent me, -8 straight swivel AN fitting with the connection type I'm used to (small threads all the way up).
Fitting #2 from Aeroquip; -8 90* swivel, but with an end that has a ferrule on it.
Here is the hose
I'm guessing I can't use all this stuff together. Should I return the ptfe hose and find the regular rubber core to use fitting style #1 like I'm used to...or should I return fitting #1 and find a straight -8 that matches the style of fitting #2?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-03-2013, 09:52 PM   #2
Marv D
Registered Truck Offender
Marv D's Avatar
Re: PTFE vs Rubber line fittings
I would returmn the ptfe stuff. It's for ultra high pressure (brake lines and P.S. hose ) I run a 58psi Magnafuel system on the LS buggy with regular ol an-6 with no hint of leaks or weeping For whatever thats worth. Just an opinion
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 04-04-2013, 02:33 AM   #3
Super73
Super73's Avatar
To add to what Marv is saying, not only have I run 58psi for years through standard -6 -8 -10 but I am now running E85 through new -6 -8 -10 and -12 summit brand braided stainless. I have left it in the cell for 3 months, no weeping and no leakage.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 04-05-2013, 12:09 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Alright well I got some rubber lined -8 and a regular AN 90* on the way, the PTFE is in the return pile. Now if only it would stay above 45* outside I could drive the thing.
Old 01-02-2016, 09:59 PM   #5
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
What did you end up going with?
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 01-03-2016, 01:44 AM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Old 01-04-2016, 07:06 PM   #7
Super73
Super73's Avatar
It is interesting that this post was brought to the top. I popped a fuel line earlier this year, -8 high pressure summit brand braided stainless. It looked at though it may had rubbed the bottle bracket so I did not think much of it.
This weekend however, same -8 (just a bit shorter now) popped again at an event pulling it off the trailer. There were no signs of running and all the braided was in perfect shape.
According to summit it was E85 friendly (non PTFE) when I bought it. I am at a point where I think I need to redo all the lines on the truck. Question is, PTFE or mostly hard line?
Old 01-05-2016, 01:17 AM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Hard line as much as possible IMO. Every hose system can be adapted to and from hard tube, and anything from Kerosene to pure Methanol wont hurt it.
Old 01-07-2016, 11:08 AM   #9
hotrod 80
mini truck racer
hotrod 80's Avatar
Some of the older rubber lined hose will "melt" after a while . The newer stuff seems alcohol resistant . I have all newer stuff and have had no problems . I am also E85 . I don't see how you get the fuel uphill in the last picture.
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 01-07-2016, 03:03 PM   #10
Super73
Super73's Avatar
Hotrod,
I redid mine less than 3 years ago. Summit promised it was the new synthetic hose that was e85 acceptable.
Old 01-07-2016, 04:12 PM   #11
Rannos
Rannos's Avatar
I ran 1/2" aluminum tubing. Just have to check your connections every now and then because of vibration. Was easy to bend and install.
Rannos is offline   Reply With Quote
