Old 02-10-2004, 11:40 PM   #1
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
4 wheel mags and information
I'm looking to build a 4wd chassis for my 56.
I would like a low nice riding frame to work from.
I owned over 100 autos and trucks but oddly enough none have been 4wd.
What are some good sources for information.
I need to sponge up as much as I can.
I have been considering 71-72s and 73-87s
Ideas?
Thanks,
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
Old 02-12-2004, 01:42 AM   #2
Scrub
Collector of rusty Items
Scrub's Avatar
Petersens 4wd and off road is great
You can get it at most newstands and it will have subscription info
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 02-12-2004, 07:11 AM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Does your 56 have a mono beam front axle and leafs up front now?
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 02-13-2004, 02:41 AM   #4
DennyB
DennyB's Avatar
Its on a 71-72 2wd, rear coil, IFS chassis now.
I'm in the hunt for a 4wd chassis to fit under it.
I doubt I'll find one that fits perfect so I will probably need to alter its length. I was thinking of a later model torsion bar IFS 4wd frame????
Any input would be appreciated
I.M.O.M,W,J&C
Patriot Guard Rider
Old 02-13-2004, 06:32 PM   #5
race2c
<--Thanks 86 Red Bowtie
race2c's Avatar
DennyB-- If you plan on doing some off road wheelin, I would recommend you get 73-87 4x4 frame. They were the last years for solid axles and are easier to lift if you plan on doing that. If you plan on getting 88-up lift kits get more expensive and you may have trouble with stock parts up front.
Just my $.02
Cam
race2c@aol.com
1941 Willys Coupe--Currently being put together. Willy Works fiberglass car.
1969 Chevy K10 SWB--SOLD!!!
1989 Chevy Silverado Z71 RCSB--SOLD!!!
1993 Pontiac Grand Prix--College Commuter
race2c is offline   Reply With Quote
Old 02-13-2004, 11:57 PM   #6
DennyB
DennyB's Avatar
Cam,
This truck is not going to be use for any heavy off roading.
I'll use it to launch my boat drive in the snow etc.
I actually want it to be lower and handle well.
And haul stuff every now and then.
Any one know anything about the 88 and up 4wd chassis?
Nice ride? dependable?
I plan to build a SBC stroker through a TH700R4 .
Not decided on the transfer case yet.
I.M.O.M,W,J&C
Patriot Guard Rider
Old 02-14-2004, 11:30 PM   #7
race2c
race2c's Avatar
DennyB-- The truck in my sig, 89 z71, has a good ride being it is a 15 year old truck. The ride is realivity good one but sometimes you feel every bump in road it seems like. The truck doesn't like railroad tracks in any way and this is with new shocks and springs all the way around. Dependability for the truck is great ever since I've had it got it, about 3 or so months ago. It starts up on the first crank and that is when it has been below 10 degrees fareinheit. The gas mileage and acceleration isn't so great. Miles per gallon is about 12-14 in the city but that is what it should get around the city. One thing I told by members of my family is "You gotta pay to play." The truck takes a few seconds to get going from a dead stop or idle, even with the TBI.
Sorry about the unnessecary info in there, and some of the stuff you probably already knew.
Cam
race2c@aol.com
Old 02-14-2004, 11:38 PM   #8
DennyB
DennyB's Avatar
Cam,
How does it handle?
Corner well?
Perhaps air suspension will help the ride?
Thanks for the info.
Denny
Old 02-15-2004, 08:55 PM   #9
race2c
race2c's Avatar
DennyB-- The truck handles well, but you can tell when you corner with the body roll or lean, if going to fast around corner or turn. It has overload springs in the back and helps when hauling a load but not as much as air bags or helper bags. If I was going to tow stuff I would put air bags on the back just to increase payload capacity. Since this is my daily driver I don't tow very often, if any and only haul stuff every once in a while. Also, I have the tires airred up as the max, which would probably increase a rough ride. I may decrease the pressure in the tires to see if it gives a mushier ride.
Cam
race2c@aol.com
Old 02-17-2004, 11:08 AM   #10
Dan72cst
Dan72cst's Avatar
I have a couple ....a 91 swb z71 and a 93 burb. The burb has a rear sway bar and they both corner really well for a 4wd. The ride in my opinion is good compared to the straight axels, but they are 4wd trucks and don't compare to a passenger car. Also both mine are half tons.
As "race2c" said the torsion bar gives it a unique feel. Its hard to explain, it kinda like a kite flapping in a big gust of wind. It has complete control but it has small rapid vibrations.
I just reread that and it confused the heck out of me....oh well. Maybe go test drive one and the local dealer.
Marysville, WA (Dan72cst@hotmail.com)
72 4wd Blazer CST 350/350
72 4wd Chevy LWB 350/350
68 2wd Chevy LWB 327/400
Dan72cst is offline   Reply With Quote
Old 02-17-2004, 06:12 PM   #11
Dean
Dean's Avatar
Practice up on changing CV joints....... I'm a pro now......lol
Dean is offline   Reply With Quote
Old 02-20-2004, 01:24 AM   #12
DennyB
DennyB's Avatar
Thanks for the input guys.
Dan72cst
What do you meen by"small rapid vibrations"?
Dean
Are the CV joints weak? do they wear out from lots of use of 4wd or do they also wear when in 2wd?
Denny
Old 02-20-2004, 06:55 PM   #13
1969 GMC
1969 GMC's Avatar
I would stay away from the IFS 4x4's...they do go thru CV joints and other front suspension pieces like crazy. Maybe I have just had bad experience, but I helped my dad work on a '9? light duty 3/4 ton 4x4 (6 lugs) with a snowplow on it, and you had to change the CV's at least once every 2 weeks when plowing. That is unacceptable. That truck also broke a stub shaft while plowing light powder across a parking lot, which was puzzling. I have never heard of something like that with a solid axle. IMO, solid axles are cheaper in the long run. There are some advantages to running an IFS (great for jumping the truck, ie in sand, and ride *can* be better- but if you are going with a 4x4, then you will always get a bit rougher of a ride).
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 02-27-2004, 07:44 PM   #14
DennyB
DennyB's Avatar
A neighbor of mine has one with a 4" lift in the rear and the front t-bars cranked up to match (done by a GM service tech).
His has over 100K on it with the orig CV's.
He did have to rebuild the front and rear "rears" though.
I.M.O.M,W,J&C
Patriot Guard Rider
