Re: Prototype center speaker holder
I ordered mine from the website the other day. I can't wait to get this little part of my project moving ahead. This should be a sweet addition to my truck considering it never had the center speaker from the factory...
Paul
Retired USAF - No rockets, no mortars, no bad guys shooting...No stress!!! ![]() My Build Thread: Project 72' Green http://67-72chevytrucks.com/vboard/s...d.php?t=587932 |
#2 | |
Kyle,
The speakers have raised lip that is just outside of the speaker surround, this lip is even with the frame edge so if the speaker hole is bigger than the O.D. of the raised lip, (3.890) then there will be gaps around the speaker. I know it probably won't have a big impact on the sound but I am OCD that way. If you can make the speaker holes a custom size then I would appreciate it and will order this from you. If you can't, or if it's too much trouble, I understand and might still order from you. Thanks, Steve |
Paul, I just wanted to give you a update. The new inserts we switched to came in, I presses them in and after a little testing ended up failing. Although they failed under a condition I dont ever see them being in, they still failed. So Im headed back to the old tried and true design. You will have yours soon.
