![]() Join Date: Sep 2015
Moving 3 on the tree to the floor.
I'm thinking about driving this truck after I do the Power Steering, Power Brakes and 4/6 Drop. But if I do I would like to move the shifter off the column to the floor. I'm told Jegs has a setup to do this. Anyone familiar with this move ?
I eventually want to go with a 700R4, which I was glad to hear the stock rearend in my truck is a 3:73 which should set up perfect with the overdrive. When I move to the 700 R 4 I'll be wanting a floor shift anyway.
Steve My Build Thread: http://67-72chevytrucks.com/vboard/s...=morning+glory 1971 C10 Inline 6 250 700R4 "Marlene" 1934 Chevrolet Master Sedan 350 700R4 "Iris" 1941 Ford 1/2 Ton 5.0 H.O Roller C-4 "Rose" 2019 Honda Ridgeline |
Re: Moving 3 on the tree to the floor.
PM sent
I wouldn't recommend that as the floor shifters I've seen for 3-speeds are located off to the drivers side of the tunnel and likely wouldn't be where you would want your auto shifter to live, they do not install in the same location as a 4-spd shifter.
Solved that problem and ordered the 700R4 this afternoon
What are you going to do for the TV cable?
1970 Base Step Side Dark Olive 250 3ott restoration 1972 k5 4x4 250 3ott project 1970 long bed light olive 283 th350 driver SOLD |
Bowtie overdrives has a great selection of TV cable items.
Ordered a 'Monster' trans and they supply the TV Cable and bracket.
