1973 C10 stock exhaust manifold flanges
Hello all.
I have a 1973 C10 with a 350 in it that I bought a few months ago. About two weeks ago I went over a railroad track somewhat hard and the exhaust broke away from the manifolds. What happened is that the exhaust broke out of the flanges (on both sides of the truck.......I know I can't believe it either) due to rust around the flanges and pipe. I have a good exhaust and manifolds from another small block 1973 junk truck but not any good flanges. The flanges I have are paper thin and the passenger flange broke into two pieces. I've looked around my local junk yards and called exhaust shops and I cannot find any 2 1/4 inch flanges for the stock manifolds. I've also looked at summit racing, jegs, autozone, napa, oreillys, craigslist and advanced auto with no luck. The truck had 2 1/4 inch exhaust on it to begin with and the "new" junk truck replacement exhaust I have is factory GM (in decent shape) and is also 2 1/4 inch pipe. Does anyone know what website or shop I can buy new flanges from? Now I know some people will say buy headers and a exhaust kit and be done with it but I'm hard headed and I don't want to go that way. I've always liked factory parts on my vehicles. ![]() ![]() Thank you for any help you can provide. |
Re: 1973 C10 stock exhaust manifold flanges
78K & 79C Jimmys
A muffler place should have them.
Definitely if they custom bend Speedy did mine
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#4 | |
What gaskets would work with the pipes and manifolds? Do I just need the donut gaskets and/or flange gaskets? Thank you for your help. |
I went to every decent muffler shop within 15 miles of my area. They either didn't have them or had them but didn't want to sell them individually. So I had zero luck with the shops.
I own a shop that bends exhaust. If they are stock manifolds on a 350 they should be 2" pipes not 2 1/4". They maybe 2 1/4" pipe with the fronts reduced to 2". Both sides should have donut gaskets. The right side(pass) should have a flat gasket, heat riser and a donut gasket. I keep those flanges in stock but they are for 2" pipe.
![]() Join Date: Jul 2000
Try Mike Forbes at Heartthrob Exhaust. mike@heartthrobexhaust.com
They ship the proper flanges for your manifolds with their 2-1/4" pipe kits. He will usually get back to you in less than an hour.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
I had a similar problem a few years ago. Do you have any "Welder" buddies?
I fabbed up a set out of a scrap piece of 3/8" plate. Used what was left of the original as a template, worked like a charm. Pickup a couple new exhaust doughnuts, and you will be good to go. |
