Old 01-10-2016, 02:16 PM   #14
rfmaster
rfmaster's Avatar
Re: new L31 crate motor to replace 87 5.7 tbi
For the record, the absolutely the worst thing you can do for L31 in originally equipped LO5 is to install a carb. Leave carburetors in 20th century where they belong. Enough said.
18 PSI spring is available from a number of sources - there are couple e-bay sellers. The one I have used before http://www.tbiparts.com/. In addition I like to run adjustable FPR from Jet Performance part # 61500 to dial in FP just right. You'll have to replace in tank FP to support highr fuel pressure. For the record L30 - the 5.0L version of vortec idles just fine with a pair of 5235206 injectors (found on 350 TBI trucks and rated around 62 lb-Hr @ 13PSI) at 17.5PSI in a 89 camaro. Engine is bone stock with GM performance intake and headers and regularly beats equipped TPI cars.
Finding a tuner is problem - Harris Performance is one option. The other option is DIY with EBL from Dynamic EFI. I prefer the later option since I tune my engines to suit my needs.
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
