Old 01-08-2016, 04:06 PM   #1
i82much
Eastern WA truck on CL (not mine)
I have a 72 K10 longbed, but I don't know much about the older ones, but is this as cool as I think it is?
https://spokane.craigslist.org/cto/5393776189.html
If it were a 4x4 I would leave work right now and buy it today.
i82much is offline   Reply With Quote
Old 01-08-2016, 04:37 PM   #2
dubds10
Stalker Nate
Re: Eastern WA truck on CL (not mine)
Yeah it's a decent price point, been for sale for awhile now as well and I think he dropped his price a bit.
1957 GMC SWB stepper modified summer time driver
1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project
1965 Chevy P10 Ice Cream Truck project
Instagram - TheDonutDiner
FaceBook - @UscreamIscream
dubds10 is offline   Reply With Quote
Old 01-08-2016, 05:06 PM   #3
1project2many
Interesting mix of old, new, and unrestored. One piece of advice I offer is that anyone getting this truck should consider splitting the driveshaft into a two piece shaft. That thing probably hits critical speed somewhere around 70 mph. Dropping tire diameter would drop the critical speed accordingly. With a single steel driveshaft that long I'd be looking for a tube measuring around 4.75" diameter.
1project2many is offline   Reply With Quote
Old 01-08-2016, 06:39 PM   #4
_Ogre
_Ogre's Avatar
i'd think that 50+ years of not falling out of there would prove you wrong
shop air compressor timer
Old 01-08-2016, 07:11 PM   #5
OrrieG
OrrieG's Avatar
Factory V8 too, bonus if the engines matches the vin. Nice truck, you can buy a rust bucket non running for half the asking price and still be working to get it running a year from now. Buy it and drive it.
Old 01-09-2016, 08:47 AM   #6
Highsider
Highsider's Avatar
Looks fun and ready-to-enjoy!
Jimi J from I-Oh-Way
'57 Panel 3105
Met this deer...
Roof Swap on my Panel
Jim's Bread Truck
Highsider is offline   Reply With Quote
Old 01-09-2016, 10:03 AM   #7
70shortfleet
70shortfleet's Avatar
The price is right for a nice rust free truck. You would save alot of money just from not having to do major body panel replacement! Can't find trucks like that around here for that price.
70shortfleet is offline   Reply With Quote
Old 01-09-2016, 10:47 AM   #8
roger55
roger55's Avatar
Keep in mind that "has very little to no rust rust" in an advertisement usually means substantial amount of rust.
roger55 is offline   Reply With Quote
Old 01-10-2016, 12:10 AM   #9
mr48chev
mr48chev's Avatar
Nice truck but the scuff and shoot and put it out for sale guys from years past made me a bit spooky of partially "restored" trucks with all too fresh paint on them,
Still it's a nice little pretty well stock cruiser for someone who wants one and doesn't want to go through the whole redo process. Being a stock longbed makes it a bit spendy for most of the prospective buyers in a 200 mile radius though.
My ongoing truck projects:
Old 01-10-2016, 12:36 PM   #10
1project2many
That's not the original driveshaft!! GM put two piece shafts in LWB trucks. You can see the mounting bolts for the carrier bearing in one photo.
Old 01-10-2016, 12:38 PM   #11
roger55
roger55's Avatar
Chevrolet put a single driveshaft in my '57 3200. I had it shortened for the install of my 700R4.
I changed the rear from the original 3.90 to a Dana 44 with 3.54 gears. That's going to slow the driveshaft down some. My tires are close in diameter to the originals as well.
Seems fine at 70 mph. I doubt if I'll drive it faster than that either.
Old 01-10-2016, 12:52 PM   #12
mr48chev
mr48chev's Avatar
On that truck you can see the bolts where the center support was with the 2 piece drive shaft along with the tag on the driveshaft from the driveshaft shop.
Good/bad I have no idea as a lot of newer trucks run some pretty long driveshafts.
Bolts for center support are circled.
Old 01-10-2016, 01:43 PM   #13
1project2many
What trans originally?
Prop shaft size and tube diameter determine critical "pretzel maker" speed. Long driveshaft is ok if it's right diameter and spinning below critical speed. Change 3.90 gear to 2.90 and long version above will go to 100+ mph. Two piece driveshaft allows smaller diameter tube and is generally less likely to suffer from torsional issues. Not that most long driveshafts have a problem, it's just a preference of mine.
Old 01-10-2016, 01:45 PM   #14
roger55
roger55's Avatar
Mine had a 3spd manual.
My 3200 has an 89" bed. The OP's truck might be a '97".
I didn't think there was a wheelbase difference in the two but not sure.
Old 01-10-2016, 03:16 PM   #15
1project2many
I'm not real familiar with the 89" bed. GM Heritage Center info shows three lengths:
Model: WB: Available Pickup Bed Length:
3104 114" 78"
3204 123" 98"
3604 123" 98"
3804 135" 108"
The 89" step bed must have been available as a specialty build? Regardless, the chart allows WB comparison.
