Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 01-12-2016, 08:52 AM   #11
cmabolt
cmabolt's Avatar
Re: 1970 K20 Restoration
Originally Posted by K20rookie View Post
Thanks for the reply Chris and congrats to you as well. I like the idea of no mods on the Dana 60. So bear with me here...I'm learning
What benefit would a Dana 60 have over the ho52?
If I'm understanding it right, I'd still have to add rear disc brakes to a Dana 60, correct? Would that just be a bolt on kit?
Is there any way to use the ho52 and just add disc brakes?
Pros, cons: ho52, Dana 60, corporate 14 bolt?
School me, I'm new to this. Basically I'd like to keep it as simple as possible and add disc brakes. Keeping the original ho52 is something I would prefer, but if parts are hard to find that may not be the best idea. Thanks
The corporate 14 bolt is the strongest of the bunch followed by the Ho52 followed by the dana 60. So why would I SUGGEST THE DANA 60 YOU ASK???, Well the Ho52 is very limited as far as what you can do to it like changing gears because they don't make them anymore. The Dana 60 is still being made today and has a ton of options if you wanted to upgrade the rear end and as far as I know the only axle available that doesn't need any mods to just drop in our trucks. The 14 bolt as mentioned is the obvious choice if you need hard core strength, but you will also need a welder in most cases to change either spring perch or shock mounts. However, they are easy to find, cheap and
strong as all get out. Any of these axles can be converted to disc brakes using kits made by various manufacturers that provide a bracket that mounts to the axle (no welding) new rotors and either truck or cadillac calipers. If ground clearance is an issue for you the Dana 60 has a smaller case than the corporate 14 bolt so that is an advantage as well. So, without a welder (dana60) with a welder (corporate 14 bolt.) BTW, drum brakes work great and no need to change to disc unless you want to. Be aware that the drum brakes since stock will allow you to maintain the stock e-brake. If you switch to disc you will need to make a provision for the emergency brake or go without one. First, You have to order calipers that have e-brake capabilities. You may need to order custom e-brake cables and have brackets made to secure them to the caliper. I have also read about people using driveline brakes or line-locks. If you read through my build you will see my solution. Cheap, but did require welding. Works great!
So that's my 2 cents. Good luck making a decision and have fun with it. Before I got a welder I was in your shoes. I wanted to change the rear without needing to weld anything. The dana 60 was my choice because it dropped right in and allowed me to change my gear ratio from 4:10 to 3:73, i was able to convert to disc and had a lit of ground clearance. I also knew I wasn't going to be wheeling so didn't need the strength of the 14 bolt.
Cheers
Chris
Project Reno Build http://67-72chevytrucks.com/vboard/s...d.php?t=392636
Easier to beg forgiveness than ask permission!
cmabolt is offline   Reply With Quote
