Transmission question
I have a 1977 Chevy short box with a bad turbo 350 what is a good transmission to replace it with?
Re: Transmission question
another turbo 350
A t56 6 speed manual will fit nicely in its spot. But it depends on what you want. Anywhere from a 200r4 will bolt in, up to 700r4, 4l60e, etc... Butbthiae require modifications. But you gain advantages
Project Roxy... Shes Bad, Low, and Blown... http://67-72chevytrucks.com/vboard/s...d.php?t=673333 |
#4 | |
modifications will I have to do ? I was thinking 700r4 |
I just did a quick search, and it appears a 700r4 is the same length as a 9" tailshaft th350. So if you still have the truck th350 you should be good to go. You will need to move your cross member back 3/4" though. And a 700r4 requires a torque converter lockup controller. A trans shop can install a hydraulic kit so no electronics are required. And then install a TV cable and you should be good.
I guess it depends on how much highway driving you plan to do.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
It really depends on what you use it for and what your final drive is.
1973 C20, 350/350 |
#8 | |
(lol) A 700R4 or a Turbo 400 would also be good choices. Might depend on what could be had locally with your cost parameters. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Unless he's making big power I don't see much reason to go 400.
1973 C20, 350/350 |
Thanks guys, found a guy that has rebuilt turbo 350 for $425 and 80 for converter.
I would rebuild the 350 you got now or upgrade to a 700r4.
Yep. For a daily driver, light hauling or light trailering it would be fine.
If you are going to start making big horsepower you might want to step up to a TH400. If you are trying to eek out some fuel economy then you may want to go to an overdrive: 700R4 or 200R4. K
The overdrive trannys might also increase your cruising speed (depending on what gearing you have).
1973 C20, 350/350 |
