02-15-2004, 10:26 PM | #1 |
lowered- front tire clearance issue
I have a 75 C-10 thats been lowered with drop spindles, unsure of the drop.
I just realized how little room I have from the top of the tire to the inner wheel well. Theres only about 1.75"-2.0" of clearance. It does rub occasionaly, like if I make a turn on a bit of a hill for example. My concern is at speed, if I where to hit enough of a dip or bump in the road & it rubs, how disasteress could this be ? Anyone else have a simialer situation ? is it a concern ? John
75 GMC C-15 short/step factory 454, lowered |
02-15-2004, 11:01 PM | #2 |
didja get new springs? If so , get progressive, and thatr that way you can maintina your height without too much trouble. Otherwise with your c10, you cna put in 1 ton springs.
02-15-2004, 11:15 PM | #3 | |
Re: lowered- front tire clearance issue
BTW: If you have 2" of clearance you should be ok. I have 2" on my drivers side and I NEVER have any problems. |
02-16-2004, 01:01 PM | #4 |
My 74 rubs ('buzzes' the tires) on most big dips going down the highway. It actually rubs the top of the wheelwell (not the fenderlip). It hasn't caused any problems & has been driven since July 03 .
02-16-2004, 07:40 PM | #5 |
scot, thats where mine would be rubbib, tops of the wheel wells. Thanks, John
02-26-2004, 03:38 PM | #6 |
Mudslides 'r my specialty
Will it rub because of the spring rate?
What if I had 2.5 spindles with 1.5 springs (Western Chassis) with 225/75-15s (28.29 overall diameter). Will I rub?
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.) http://www.cardomain.com/memberpage/500339 |
02-27-2004, 04:06 AM | #7 | |
02-28-2004, 12:47 AM | #8 |
5-7 dropped 87 CC Dually
Why don't you'all make the bump stops taller so the tire dosn't hit?
I rather be in my 77 Sanger Picklefork Jet Hydro! |
02-28-2004, 07:07 PM | #9 |
Bumpstops
Well, on mine, if the bumpstop were taller than stock, it would contact the bottom of the c-member all the time.
The ones I currently use are trimmed down stockers (about 3/4 to 1" trimmed off). I'm going to replace them w/stock height bumpstops & that will cut down the rubbing considerably (I use a similar set-up on my 68 & it hardly ever buzzes).
