Old 01-15-2016, 03:28 PM   #1
Marla
Horn woes
I am putting on a 1959 Impala steering wheel and I think I need the metal contact plate...not the plastic plate I received with my steering wheel...I have it all lined up but I cannot get the horn to make contact...and yes I have read about 20 past posts on this subject...learned a lot but still need a bit of help...Marla
Marla is offline   Reply With Quote
Old 01-15-2016, 08:22 PM   #2
Gromit
Re: Horn woes
I struggled with that too when I first bought my truck from the previous owner.. finally put a jumper from the battery to the terminals on the actual horns just to see if they worked and found that both of them were dead.
So are you sure your horn (the one(s) behind the grill) works? Also I'll bet if you post a photo of that super cool 59 Impala steering wheel someone will know which disk to use..
Gromit is offline   Reply With Quote
Old 01-16-2016, 03:45 PM   #3
Marla
Re: Horn woes
Okay...here are a couple of photos...I figured out the horn problem too...not bad for a girl huh?...Marla
Old 01-16-2016, 05:48 PM   #4
Lattimer
Lattimer's Avatar
Re: Horn woes
For the sake of future searchers, what was the problem?
That wheel looks cool!!!
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 01-16-2016, 05:53 PM   #5
7tee
7tee's Avatar
Re: Horn woes
Nice, I like it...ed...
1970 C/10 350/T5 SWB stepper...
1979 Corvette 350/Auto T-top...
2010 Acura RL...
2015 2500HD Z-71 Silverado...
7tee is offline   Reply With Quote
Old 01-16-2016, 06:27 PM   #6
Marla
Re: Horn woes
The cancelling cam pin was not making a good contact...I used a new spring from an ink pen and it worked perfect...got to love 50 year old technology...M
Old 01-17-2016, 12:19 AM   #7
Gromit
Re: Horn woes
That steering wheel is totally cool - nice choice!
Where is the seatbelt for your date? What is (s)he, chopped liver? You need one in the middle so they can schooch all the way over without risking a broken nose on the rear view mirror.
Plus if you ever make a wrong turn down a residential street in East LA Homies might take note and (maybe) give you a pass.
