Use caution heating your garage !
Working on the old truck - I cleaned my front brakes off with brake cleaner. Fired up the kerosene heater and went to work. I was working in a tight corner of the garage. For what ever reason the fumes of the heater and the brake cleaner kinda lingered in that corner where I was working. Started feeling bad, I went outside for fresh air and felt better.
The next day I had a hard time getting my breath and my chest hurt, but the day after I felt fine. Usually the kerosene heater doesn't bother me, but mixed with the brake cleaner fumes it caused problems. BE CAREFUL OUT THERE !!
If you don't like this ![]() |
But Found Her 25yrs Later!
Re: Use caution heating your garage !
Glad you're okay.
Mixing chemical fumes can be dangerous.
![]() Join Date: Mar 2013
I have wood heat in my garage. When I painted my engine in the winter and had the stove on it seemed like the fumes were 3 times worse than normal....simple reason because all doors and windows were locked tight to keep SOME warm heat in. After 4 hours of painting I had taken probably 7+ air breaks as I would get a headache from the fumes. lol So I now save my painting for the summer mornings. haha
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
![]() Join Date: Jan 2009
Brake cleaner is a killer.
Just remember that they still need oxygen to burn, so in an enclosed space you're also removing oxygen. When you take that away there is less to dilute the other chemicals in the air, so you're getting the other fumes in greater concentration. I used a forced air propane heater for awhile, and kept the garage door cracked. Eventually I got tired of using propane, or having cool air and warm air mixing, so I coughed up the money and did a standalone heat-pump style unit in the garage.
Now I can keep it at a nice 65* year round, unless it gets particularly hot (95*+) and then the coolest I can get it is about 72, which is still comfy. |
No kidding right? Been welding for 40 years and just discovered this. Acetone is my only cleaner now....
http://www.brewracingframes.com/safe...sgene-gas.html
'66 C10 SWB '64 C2 roadster '38 Indian Scout Flattracker '70 Triumph T120R '81 Laverda Jota |
#7 | |
![]() Join Date: Feb 2015
damn glad your ok ! Also swearing off brake cleaner
It was phosgene gas. The CFCs in the brake cleaner burned through the heater. An old story and a deadly one at that.
Just use "California" brake cleaner. No CFCs. It does not clean as well, but at least you will be alive to scrub harder. ![]()
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
#10 | |
I was going to post this link. Very dangerous stuff gentlemen. |
phosgene gas !? great...... won't be doing that again.
![]() Join Date: Jun 2012
Nasty stuff!
Phosgene is the chemical compound with the formula COCl2. This colorless gas gained infamy as a chemical weapon during World War I where it was responsible for about 85% of the 100,000 deaths caused by chemical weapons.
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son ![]() |
I knew about the dangers of brake cleaner when welding. Now I think I will not use brake cleaner under any circumstances.
Had a buddy spend a week in the hospital over use brake cleaner around a kerosene space heater
