Old 01-14-2016, 03:28 PM   #1
K20rookie
ORD Steering Box Brace Kit
It's my understanding that these trucks are notorious for frame cracks/breaks near the steering box. I want to install the steering box brace kit from ORD, and I need some advice. Here's a link to the kit: http://www.offroaddesign.com/catalog/steeringkit.htm
So here's the deal...my front crossmember is the straight design, as opposed to the crossmember that curves back toward the rear of the truck. According to ORD's website, their kit was designed around the crossmember that curves toward the rear. In order for it to work on my crossmember, I'll have to do some modifications. What would be the best way to fill this gap and mount the bracket to the crossmember? Does anyone know of another company that makes a steering box brace kit like this?
-Nick
1970 Chevy K20 Restoration
2001 Chevy Suburban 2500
K20rookie is offline   Reply With Quote
Old 01-15-2016, 12:46 AM   #2
Zoomad75
K5Camper
Zoomad75's Avatar
Re: ORD Steering Box Brace Kit
Best advice... Call them when they are open. I'm pretty sure they can give you the insight to use it on the straight crossmember.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 01-15-2016, 01:03 AM   #3
First c10
First c10's Avatar
Even though my truck had the correct crossmember or maybe It didn't but I still had to add 1/2" spacer. A few others here on the forum had to modify it quite a bit and some not so much. Check out the build threads on the 4x4 build thread area. Good luck. Check out my build thread and dwilber's thread we both installed them in different ways.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 01-15-2016, 10:23 AM   #4
joeydurango
joeydurango's Avatar
If I recall correctly - sold that truck so I can't go look - I used a fairly large spacer on my ORD kit to meet the crossmember. Once bolted in place it seemed very solid, no worries about the spacer whatsoever. Will probably add one of these to my new Super when it gets here!
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER
1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD
1976 Trans Am | 400/4-spd | SOLD
1976 Trans Am | 455/4-spd | TOTALED
joeydurango is offline   Reply With Quote
Old 01-15-2016, 10:53 AM   #5
K20rookie
I called them yesterday and they suggested a spacer similar to what others have done on this site. Shouldn't be too much of an issue for this rookie
-Nick
Old 01-15-2016, 11:52 PM   #6
swclassics
swclassics's Avatar
I had a similar problem on my 71 K10. After talking with ORD, I ended up using washers to space it out properly on both frame and crossmember (see pics). I also ended up cutting a "window" in the bracket to be able to route brake lines cleanly.
swclassics is offline   Reply With Quote
Old 01-16-2016, 10:52 PM   #7
K20rookie
This is exactly what I was hoping to see. That looks super clean. Thanks for the pictures. Any chance you remember what size washers you used? Also, I'm curious, did cutting that window make it a lot easier to route the brake lines? I planned on just routing them around the bracket when the time came, but now you got me thinking.
-Nick
Old 01-17-2016, 10:29 AM   #8
swclassics
swclassics's Avatar
The washers were the same size as the bolt but were extra large outside diameter to match the size of the bracket. I found them at the hardware store. It's not necessary to "window" the bracket, it just made the routing cleaner on my truck. Your's may be different. The bracket works GREAT in stiffening that area of the frame. Frank
