![]() Join Date: Mar 2007
Re: FITECH EFI 600 Basic and Command center intall with pics, factory tank
You mentioned a two wire dist. Does it require you to make any changes to your dist? I have installed the gm tbi systems. If you let the ECM control the timing it runs even smoother. Do they sell a dist with this kit? I put a GM TBi on my 72 K-5 and it ran great fuel mileage went from 9 to 13-15 on 35" tires. Ran great. I like these systems but still not sure about that tank up front. I should find their site and look around.
1968 SWB "Little White Truck" 1972 LWB LS 4l80 "Plain Jane!!" |
#2 | |
1967 c10 3OTT with R10 overdrive. 385 Stroker, 373 posi FITECH EFI, Vintage air, York 210 OBA, 4/6 drop with riddler 20x8 and 20x10 1957 S5T Leslie Supertyfon train horns and EMD bell "No bolt left unturned" |
#3 | |
But Found Her 25yrs Later!
I'm thinking about installing mine on the passenger side inner fender back by the heater. Edelbrock also has a sump tank unit that many mount up front on the radiator support. Go to YouTube and watch install videos of the Holley Terminator, MSD Atomic, EZ-Fast, and the Edelbrock E-Street. Many Pump/Tank install options with or without the SumpKit/FCC.
#4 | |
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
#5 | |
There's a guy in these forums that made his own. Here's a couple threads where there's been some previous discussion : http://67-72chevytrucks.com/vboard/s...68#post7450468 . http://67-72chevytrucks.com/vboard/s...d.php?t=686601
