Old 01-17-2016, 03:16 PM   #1
Jferrante
Jferrante's Avatar
Leaving car in gear - burning smell and squeak
Hey quick question. My 64 c10 has no ebrake cable hooked up at the moment (on order) so I am leaving the car in gear when I park it. When I start her up again and try to move I encounter some resistance and get a squeaking noise and a burning smell. Something has to be activating somewhere...I haven't gotten under just yet but is this something with the tranny or braking system?
Thanks for guidance
Jferrante is offline   Reply With Quote
Old 01-18-2016, 01:16 AM   #2
Captainfab
60-66 Nut
Re: Leaving car in gear - burning smell and squeak
I assume this is a manual trans? I always leave my manual trans cars and trucks in reverse when parked and I've never had any of these issues.
Old 01-18-2016, 01:20 AM   #3
Jferrante
Jferrante's Avatar
Yes - me too. I tried to push the car as well in neutral and it wouldn't roll. The weird part is when I drove away it was sqeaking and burning as if the parking brake was on....going to have to get under and see whats up.
Old 01-18-2016, 01:49 AM   #4
Captainfab
60-66 Nut
When was the last time you checked the oil level in the trans?
Old 01-18-2016, 08:58 AM   #5
PGSigns
PGSigns's Avatar
If it wont roll in neutral then there is something broke. Could be a stuck brake, a bad bearing in the rear end or the trans is toast.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-18-2016, 09:33 AM   #6
Jferrante
Jferrante's Avatar
Jimmy
Thanks - the trans was fine until yesterday. The battery actually died on me so we tried to roll it and it wouldn't go anywhere. Jumped her and took off - got the squeak and burning smell but eventually went away. I will check the above. Thanks everyone.
Old 01-18-2016, 12:01 PM   #7
Backpayne
Sounds like you have a seized/stuck brake. If it happens again, put truck in neutral and jack up and try to spin each wheel. That would identify your source.
Backpayne is offline   Reply With Quote
Old 01-18-2016, 01:16 PM   #8
The Rocknrod
Moderator
The Rocknrod's Avatar
Originally Posted by Jferrante View Post
... try to move I encounter some resistance and get a squeaking noise and a burning smell...
Yep - That would be my bet.
Old 01-19-2016, 07:12 AM   #9
Jferrante
Jferrante's Avatar
Thanks guys threw it on stands last night. Back left wheel moves freely but the right is stuck, it will move back with some force. Looks likesomething seized in the drum. Will pull it apart this weekend and go from there.
Old 01-20-2016, 01:28 AM   #10
60chevyjim
60chevyjim's Avatar
my wife was out shopping and she had a similar problem.
I went to get her and the car , it felt like the ebrake was on when I tried to move the car.
she doesn't use the ebrake and it wasn't pressed down.
after I managed to get it home . when I pulled the tight brake drum off .
witch I had to adjust the brakes looser to get it off...
the bonded brake lining had came loose from the brake shoe and it fell off when I got the drum off . the lining was binding up the rear brakes .
I put some new brake shoes on and the problem was solved .
it was a 94 buick roadmaster wagon ..
60chevyjim is offline   Reply With Quote
