Old 01-11-2016, 01:45 AM   #126
DblTrbl
DblTrbl's Avatar
Re: My 83' Crew Cab Dually project
Originally Posted by 54earl View Post
I just bought an 82 crew cab dually (200). No engine or trains, but I have a small block 350 and a turbo 400 as well as a 700r4. I have been trying to figure out a good bag selection and if the 350 would work out.
The 350 seemed to push mine along just fine. It sucked at highway speeds, but that was the TH400. I towed my 25' boat around last summer without issue. I haven't heard good things about towing with the 700R4's, but I may drop one in just to get that overdrive.
I'm using Air Lift Dominator 2600's all the way around. It lifts the front just fine and I don't expect that the rear will weigh any more than the engine. Do yourself a favor though and run multiple tanks. 5gal was barely enough to lift the front once.
83 Crew Dually build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=686192
Instagram: lofab77
DblTrbl is offline   Reply With Quote
Old 01-11-2016, 01:52 AM   #127
54earl
54earl's Avatar
i have dual air compressors might as well have dual tanks. Thanks for the info on the bags. I am looking forward to seeing yours up and running.
54earl is offline   Reply With Quote
Old 01-12-2016, 12:40 AM   #128
DblTrbl
DblTrbl's Avatar
I had a REALLY frustrating day with my pulley and bracket kit. Nearly everything required some form of clearancing, bolt holes are off center, the water pump pulley has been countersunk so far that the bolts seat well below the surface, the alternator fan hits the alternator body when bolted together, the heim joints interfere in both ends so the bolts can't be tightened, the power steering pump bracket gives very limited belt adjustment. I found that I have the wrong shaft on my power steering pump. I really expected that bolting the shiny parts on would be more fun.
A little more progress...
Instagram: lofab77
Old 01-15-2016, 12:37 AM   #129
DblTrbl
DblTrbl's Avatar
I got the crossmember built and tacked in place. I still need to build some filler pieces and burn the whole thing in...
Instagram: lofab77
Old 01-15-2016, 11:28 AM   #130
aggie91
I'm just glad to be here!
aggie91's Avatar
That looks good.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-15-2016, 12:32 PM   #131
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Man that looks good and really heavy.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 01-15-2016, 01:48 PM   #132
daddyjeep
daddyjeep's Avatar
The way he built it makes it look a lot heavier than it is. I love details like this. Nice work.
daddyjeep is offline   Reply With Quote
Old 01-15-2016, 01:54 PM   #133
tinydb84
tinydb84's Avatar
So much work. I would have dimple died a piece of sheet and called it a day. Actually I probably would have been too lazy to do that and just used a sheet.
How thick of material did you use? I am trying to figure out how I want to run the cross members in my truck...
David
Instagram: myfabguy
Old 01-15-2016, 05:38 PM   #134
DblTrbl
DblTrbl's Avatar
Thanks for the compliments guys.
Each section (3 of them) weighed around 10lbs. It's 3/16" with 1/8" wall tube. Like Tinydb84 said...it was a lot of work. The most time consuming part was smoothing out the welds on each hole...both sides. A carbide bit worked well, but it took time. This area is kind of where I can get artistic with the framework, so it was worth the hours that I had to dedicate to it...
Here's some progress on the fillers that I'm doing.
Instagram: lofab77
Old 01-15-2016, 07:00 PM   #135
TrailerTrash
TrailerTrash's Avatar
wow this looks amazing keep it up
TrailerTrash is offline   Reply With Quote
Old 01-15-2016, 09:38 PM   #136
ruffrida2005
Looks good buddy.
Paul
Old 01-17-2016, 04:16 PM   #137
DblTrbl
DblTrbl's Avatar
Finished burning it all in. Just need some filler and final prep before paint. I got my power steering pump issue worked out. I had to order one for a 71' Monte Carlo to get the correct main shaft for my pulley. I'll be bolting that up shortly and then dropping the engine and trans back in so I can start cutting the floor.
Instagram: lofab77
Old 01-17-2016, 05:07 PM   #138
Advanced Design
Advanced Design's Avatar
Very cool build! DblTrbl, you have some awesome fab skills. I am tagging along for the rest.
Advanced Design is offline   Reply With Quote
Old 01-18-2016, 04:00 PM   #139
Task Force Era
Task Force Era's Avatar
Man I forever regret the day I got rid of my 87 crew cab dually!
Sick build man, I'm loving it!
Task Force Era is offline   Reply With Quote
Old 01-18-2016, 06:19 PM   #140
64chevtruck
Nice details DT. The extra time you put into making that frame look stylish is well worth it I think. Cant wait to see it painted.
Keep up the good work.
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438
70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983
76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612
79 GMC 3500 Fleetside LB 454/400
90 Suburban Silverado 4x4 350/700R4
97 1500 Cheyenne Short Fleet 350/5sp
64chevtruck is offline   Reply With Quote
Old 01-19-2016, 12:32 AM   #141
DblTrbl
DblTrbl's Avatar
Thanks guys...
I lifted the cab off today - I should have done that months ago, but these things snowball and I've been trying to be the least intrusive as possible...clearly that hasn't worked for me so far. Haha!
I also got the engine and trans temporarily mounted in place so I can finish out the trans mount/crossmember and the carrier bearing crossmember. Then I'm on to marking and cutting the floor. At this point it's looking like I'll be tunneling the entire length of the cab for the driveshaft...what I'd give to have a slip roller at my disposal.
Instagram: lofab77
Old 01-19-2016, 03:46 AM   #142
ruffrida2005
That's looking good buddy, I wish I had the room to put my truck in my garage, but i'm about 1' and half too short.
Paul
Old 01-19-2016, 06:39 AM   #143
64chevtruck
Snowball.......ain't that a fact....
Hey maybe you could find a concrete truck chute, or the right size metal pipe to cut in half to use for your tunnel?
Old 01-19-2016, 07:27 AM   #144
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
I am going to do the same, tunnel all the way back. I haven't even measured but I know the Cummins I'm using has a terribly high crank centerline.
How about sideways!
1988 Chevy R30 Dually Crew-Cab - Build thread Cummins swap + Bagged and Bodied on Semi wheels, work in progress
Ghostwhite is offline   Reply With Quote
Old 01-19-2016, 07:58 AM   #145
ruffrida2005
How about sideways!
No sir. That would be even worse. I hate these small 2 car garages. My NBS Silverado crew cab with short bed hardly fits with the door down.
Paul
Old 01-19-2016, 01:35 PM   #146
daddyjeep
daddyjeep's Avatar
I feel for you...it's really hard to turn my truck around inside the shop without moving other vehicles out of the way.
[IMG][/IMG]
Old 01-19-2016, 02:46 PM   #147
Low Elco
Great lookin' fab work, and educational. Please continue!
Low Elco is offline   Reply With Quote
Old 01-19-2016, 10:25 PM   #148
DblTrbl
DblTrbl's Avatar
I was able to get the carrier bearing crossmember mounted up and the drivetrain bolted together for mock-up. Preliminary cut on the floor is done. Not one inch of the driveline would have cleared the stock floor. I'm afraid that I'm going to be forced to go with buckets or do some modifications to both benches. The tunnel is going to be taller than the bottom of the seats. I may also be trimming the back wall of the cab a bit. I haven't been able to drop the whole thing down yet to see where the driveline lands.
The hood is going to be tight fit. I hadn't planned on it, but a cowl hood may be a necessity...
Instagram: lofab77
Old 01-20-2016, 12:25 AM   #149
Low Elco
ps-love the boat!
Old 01-20-2016, 01:39 PM   #150
tinydb84
tinydb84's Avatar
Have you thought about lowering the engine an inch or two? I got mine down 2.5 inches (its an LS though). You already got everything cut out but it may save some of the headache of messing with the seats.
David
Instagram: myfabguy
