Old 01-18-2016, 09:49 PM   #1
GMC5.3
Is this the right heater core
So today upon changing some hoses I got really luck and tore off a nipple from the old heater core, I've done a little research on people getting aluminum cores and others saying to go brass.
Has anyone got this brass one from autozone and it be a better fit than the aluminum ones
http://m.autozone.com/cooling-heating-and-climate-control/heater-core/pro-source-heater-core/chevrolet/blazer-4wd/1972/8-cylinders-5-7l-4bl-ohv/470359_0_0/?location=
GMC5.3 is offline   Reply With Quote
Old 01-19-2016, 12:23 AM   #2
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Re: Is this the right heater core
I used this one. Been in the Blazer for more than 10 years.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 01-19-2016, 09:09 AM   #3
GMC5.3
Hey Bobby , so I'm assuming you got that one from autozone? You didn't have to modify the brackets
Old 01-19-2016, 11:57 AM   #4
BobbyK
BobbyK's Avatar
I either got it from Pep Boys or Napa, can't remember.
It fit right in. No modification to the stock brackets.
This is an A/C core. The tubes are routed different on a non A/C heater core.
Old 01-19-2016, 12:35 PM   #5
GMC5.3
Got it, well I appreciate the reply back, atleast I know there is hope getting one local and at a cheaper price
Old 01-19-2016, 08:07 PM   #6
GMC5.3
can anyone give me some advice on how to disconnect the. Temperature cable so I can get the heater box off?
Old 01-19-2016, 08:51 PM   #7
jaros44sr
jaros44sr's Avatar
Those pal nuts can be a son of a gun, I usually just grab them with channel locks and rip them off, make sure you have a source for a new one, haven't ever been able to save them
Once you get them off, you'll see 2 or 3 paws that grip the rod. that's the problem, haven't been able to release and reuse them
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
