01-19-2016, 05:53 PM | #1 |
carb rebuild kit deterioration after less than 6 months
I rebuilt the carb about 6 months ago and the plunger boot has cracked .. Is it possible to remove and replace the pump plunger without have to pull the carb again ? .. Its a Rochester 4GC I got a new boot coming from
01-19-2016, 06:25 PM | #2 |
Re: carb rebuild kit deterioration after less than 6 months
If I have to pull the carb I'm just gonna replace it cause rebuilding it every 6 months is gonna blow
01-19-2016, 07:04 PM | #3 |
The problem is the fuel it has too much alcohol and cheap rubber. Is it the dust boot on top or accelerator pump. You don't have to rebuild the whole thing.
01-19-2016, 07:07 PM | #4 |
Who Me?
The Chinese and Ethanol do not mix well. Maybe there is a better kit out there.
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
01-19-2016, 08:04 PM | #5 |
I think you have to pull the top of the carb off to get the plunger out. Possible on the truck, but if you drop a screw down the bore....
I agree on the ethanol and the plunger. Maybe you can search for a better one. |
01-20-2016, 03:47 AM | #6 |
The rubber is definitely cheap .. So I find the boot on eBay cause I don't want to buy another kit for just a boot .. I don't think California gas has ethanol .. Gonna replace boot and if I'm still getting weak fuel delivery than I'm pulling the carb and popping the horn .. I did let it sit for a while when I was wiring up the lights and replacing the doors
01-20-2016, 09:55 AM | #7 |
