Old 01-07-2016, 11:59 PM   #876
99 to Life
99 to Life's Avatar
Re: 1949 Chevy 3600 into a daily driver
check ebay, prolly find a set for sure.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 01-10-2016, 10:05 PM   #877
Coach529
Coach529's Avatar
Not much forward progress lately.
The IRS is mocked up and tacked. I made some templates for a bigger notch and those are at the fab shop getting cut.
I spent about 6 hours in the car over the last couple days and most of it was spent thinking of where and how best to mount my compressors and air tanks. Spent a little time tonight mocking it up.
I plan on drilling some holes for my leader hoses to go through the cross member to the tank.
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 01-10-2016, 10:47 PM   #878
Advanced Design
Advanced Design's Avatar
Packaging components on a build sure takes time. Look, think and measure...too often I short myself on the think part.
Good looking components and location.
Advanced Design is offline   Reply With Quote
Old 01-10-2016, 10:48 PM   #879
99 to Life
99 to Life's Avatar
been there done that, takes longer than ya think moching stuff up. Ur gas tank still behind the seat I assume?
Old 01-10-2016, 10:51 PM   #880
Coach529
Coach529's Avatar
Thanks.
In my mind I figured I had enough room for a drop down battery box in the area as well. It did not work out once I start putting stuff in place.
Now I need to find a place for the Battery. UGGGHHH. :-)
1949 Chevy 3600
Old 01-10-2016, 11:03 PM   #881
99 to Life
99 to Life's Avatar
so you're talking about battery out in the back? it won't fit between the compressors? How far down would you be able to mount below your frame?
Old 01-10-2016, 11:03 PM   #882
Coach529
Coach529's Avatar
Yes it is.
1949 Chevy 3600
Old 01-10-2016, 11:05 PM   #883
Coach529
Coach529's Avatar
I was actually hoping to build a box for the battery between the IRS and the air tank but there is not enough room.
It might fit between the compressors, but I had that space reserved for a couple holes for the leader hoses to go to the tank.
1949 Chevy 3600
Old 01-10-2016, 11:26 PM   #884
99 to Life
99 to Life's Avatar
well reason I ask on your below frame location is.... if you mount below frame line, then perhaps you can play with mounting comps upright and getting a different angle on your lines. (I'm just a stickler for upright mounting on comps even though side mount still works). I'm seeing a couple ideas but without knowing sizes of things by the pics, its hard to say if it would work.
1.what if the comps where butt up to each other, heads facing one another and the hoses run through frame in the center, then to the space that is now left (where old compressor location was) you can mount a battery there.
2. any benefit to swapping air tank location with comps? if that area is bigger maybe the battery can go there too.
3. more work than necessary maybe, but... you can move the xmember back and have more room, seems to be about 6" from back of frame to comps, is that possible to utilize that space?
4. easy way out, can leader hoses go under that xmember if you had battery in middle?
Old 01-10-2016, 11:47 PM   #885
Coach529
Coach529's Avatar
Now you got me thinking.
I headed back out to the shop. Damn it is cold here. -10 right now. OK so if mount the compressors upright and side by side I would have room for a custom battery box as well a small mount for a box to hold compressor relays and main power fuse.
I did not have enough hands to hold both compressors and take a pic.
I have to do some research to see how much room I have on the top of the frame before I hit the bottom of the box.
1949 Chevy 3600
Old 01-11-2016, 12:18 AM   #886
99 to Life
99 to Life's Avatar
yes that seems like it would be good right there. I was thinking that same set up, but bf the xmember. wasn't sure if you had the length or not, but that is cool there. If I can recall, with the 53 and earlier beds, they have a wood block on some of the mounting points and some xmembers, so isn't the bedwood atleast that high off the frame, like about 2"? you could also easily make a drop mount for your compressor to mount off your frame and drop the comp down about an inch or whatever you need.
Old 01-11-2016, 10:31 AM   #887
Coach529
Coach529's Avatar
I am going to look at it some more tonight. Not 100% sold on any of the ideas yet.
My main concern is I do not want to be able to see the stuff once the bed is on from the back.
I plan on running a rear bumper, so that will help.
1949 Chevy 3600
Old 01-11-2016, 11:08 AM   #888
99 to Life
99 to Life's Avatar
yah I feel yah there. bumper helps and or a filler pan you can easily fab up.
Old 01-11-2016, 06:59 PM   #889
Fountain
In your spring cup there is a pipe, how will that affect your bag installation or does it?
Fountain is offline   Reply With Quote
Old 01-11-2016, 09:58 PM   #890
Coach529
Coach529's Avatar
It is not the end of the world to leave the battery in the stock location either......
1949 Chevy 3600
Old 01-11-2016, 10:01 PM   #891
Coach529
Coach529's Avatar
I will build a cup to fit over the pipe.
Similar to this:
1949 Chevy 3600
Old 01-14-2016, 04:05 PM   #892
Coach529
Coach529's Avatar
According to some rough measurements with a 27" tall tire, and stock spindles my running boards will be about 4" off the ground.
I am loosing some travel due to the upper ball joint binding up.
So the question is:
Pie cut stock UCA?
Buy Pro Forged Super Travel Upper Ball Joints
Buy Tubular Upper Control Arms
I plan on dehumping the Lower Control Arm to accept my bags
1949 Chevy 3600
Old 01-14-2016, 04:06 PM   #893
Coach529
Coach529's Avatar
http://*************/control-arms/co...10-ball-joints
1949 Chevy 3600
Old 01-14-2016, 04:51 PM   #894
lower50's
lower50's's Avatar
I would go with tubular UCA made to be lowered, they will be better all around.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 01-14-2016, 04:56 PM   #895
Coach529
Coach529's Avatar
Any suggestion on a brand?
1949 Chevy 3600
Old 01-20-2016, 12:45 PM   #896
Coach529
Coach529's Avatar
progress......slow but sure.
1949 Chevy 3600
Old 01-20-2016, 01:09 PM   #897
ptc
ptc's Avatar
Hey Coach..... just an idea on the battery location mount etc....
Right behind or in front of your rear wheels OUTBOARD of the frame you could hang a battery box like this (or enclosed) and it would be easily accessible with side/top posts.
Mine is outboard in front of the right rear wheel, using an Optima 34/75 series. I'll have an access hatch above it in the aluminium bedfloor.
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 01-20-2016, 01:16 PM   #898
Coach529
Coach529's Avatar
Right behind or in front of your rear wheels OUTBOARD of the frame you could hang a battery box like this or enclosed and it would easily accessible with side posts.
Mine is outboard in front of the right rear wheel. I'll have an access hatch above it in the bedfloor.
That is a nice looking box.
I will be running my headers up and over the frame so they will be between the frame and the running boards.
Right now I am thinking underneath the bed between the frame rails. Drop down box.
1949 Chevy 3600
Old 01-20-2016, 01:29 PM   #899
99 to Life
99 to Life's Avatar
have you put the tire on and try lowering it? notch looks good, keep us posted. stock spindles and 4" off ground is low. Keep in mind if you measure off the bottom of your running board bracket, the running boards actually set down another inch past that. so if you're 5" off your Running board bracket, your RB would be 4" off ground.
Old 01-20-2016, 01:35 PM   #900
Coach529
Coach529's Avatar
stock spindles and 4" off ground is low. .
That is layed out......not at ride height.
1949 Chevy 3600
