Old 01-20-2016, 11:14 PM   #2
lovemy71s
lovemy71s's Avatar
Re: Routing headlight harness a clean way?
On mine right after the big plug I ran it inside the fender I guess you would say to the first headlight then I ran it under the radiator support to the other side. Left it all tucked down, mine is also a new painless kit so I had extra wire to work with. Its currently tore apart but should be back in the shop in a couple weeks to get its powerplant returned I could maybe get pics then if you needed.
lovemy71s is offline   Reply With Quote
