Old 01-21-2016, 01:16 AM   #26
'68 Newtricks
'68 Newtricks's Avatar
Re: Cpp modular drop spindles and wheel backspacing
Having spent thousands of dollars with CPP, I'd won't buy or even trust what they say again. So much BS and back tracking. Descriptions say one thing, dude on the phone says another thing and calls the description out for being wrong. WTF
Here is my 2.5 modular spindle + 2 spring running 275/40/20 mounted on 20x8.5" rims all the way around. I will try very hard to get what my backspacing is in the next couple days. Personally, I wish it was another 3/4" more on either side. Please please, someone message me if I haven't by Sunday.
'68 C10 SWB
'85 K30 Blazer
'68 Newtricks is offline   Reply With Quote
Old 01-21-2016, 01:19 AM   #27
'68 Newtricks
here are two more shots
I have zero miles on this truck so the alignment hasn't been done yet, might be off on the driver side camber
'68 C10 SWB
'85 K30 Blazer
Old 01-21-2016, 04:44 AM   #28
Cooper Restorations
Cooper Restorations's Avatar
That looks good!!!
Cooper Restorations is offline   Reply With Quote
Old 01-21-2016, 11:09 AM   #29
StupudMunkee
I'd be very interested in the backspacing there too. I've seen the 6 lug version of these (AR104 - 20x8.5 w/ 5.5bs) on a 70 c10 and they required the hub being machined and 2" spacers.
I am about to install the Hotchkis TVS and CPP Big Brake Kit with 2" Modular Drop Spindles on my 1970 C10 SWB Fleetside. I am planning on 20x10 American Racing VF494 (6 lug version of VF493). Due to the lead time on building the wheels, I am trying to determine the BS before starting the work.
Does CPP make a 2.5" Modular Drop spindle?
StupudMunkee is offline   Reply With Quote
Old 01-21-2016, 12:58 PM   #30
lolife99
67-72 parts collector,…
lolife99's Avatar
No.
Just standard 2.5" drop spindles and 2" Modular spindles.
Keith
Convert to disc brakes.
Old 01-21-2016, 03:46 PM   #31
jus2qwk
jus2qwk's Avatar
I have the modular drop on mine and PB control arms. I just ordered wheels yesterday
I went with 8.5 with 5in bs. I hope it works out!
Corey Jones Designs
CoreyJonesDesigns on instagram
Ole Silver- 1967 stepside
http://www.hotrod.com/articles/1103c...chevrolet-c10/
http://67-72chevytrucks.com/vboard/s...d.php?t=598758
jus2qwk is offline   Reply With Quote
Old 01-21-2016, 10:44 PM   #32
'68 Newtricks
No.
Ok, then the above picture has 2" + 2". I feel like it's lower than many other trucks running similar tires but with 5-5.5" of drop. I'm debating raising the front some or lowering the rear. It's a DD, so that's why I'm worried about the front clearance.
Anyway, yes, they are modular. The ones with the separate billet bearing carrier. PN 7387swbk-5
'68 C10 SWB
'85 K30 Blazer
Old 01-21-2016, 11:23 PM   #33
BossHogg69
motor exploder
BossHogg69's Avatar
CPP standard 2.5" drop spindles, Hotchkis 2" springs. 19x9, 6" b.s., 275/35 tire. I would've liked a bit more lip in front, but these fit perfect and don't rub. I did a lot of research and measuring before telling the guys at Schott what I wanted. Mistakes can get expensive when getting custom made wheels.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 01-22-2016, 06:08 AM   #34
lolife99
lolife99's Avatar
Looks perfect to me.
In my opinion you did it right.
Add suspension,... Then measure for wheels.
Not the other way around.
Keith
Old 01-23-2016, 04:24 AM   #35
68ls1
68ls1's Avatar
That looks pure
Are those sizes, just the fronts? What size are rears?
Do ou have a build thread? Please post more pics.
68ls1 is offline   Reply With Quote
Old 01-23-2016, 12:04 PM   #36
'68 Newtricks
No.
The "table of contents" for CPP's catalog says 2" modular spindles. Click on the details and you get...
Our exclusive new design gives you 1-1/8" more clearance at the fender and helps solves tire to fender interference commonly found with lowered trucks. Spindle and brackets works with factory 1971-87 C10 brake components. The ALL NEW CPP Modular Spindle offers many benefits available for the first time, installs easy without modifications, works with factory ball joints and tie rod ends, lowers your truck a full 2-1/2".
It also says 2.5" in the blue section of the online catalog.
as far as I can tell, if your spindle uses a bracket to hold the caliper, instead of it being cast into the spindle, they are "modular". Mine use the bracket and separate billet wheel hub.
So..... I don't get it hahaha
'68 C10 SWB
'85 K30 Blazer
Old 01-23-2016, 06:41 PM   #37
BossHogg69
motor exploder
BossHogg69's Avatar
Originally Posted by 68ls1 View Post
That looks pure
No build thread, but I have pics of the build posted on my profile page in my albums. Rear wheels are 19x12, 345/30 tires, 6" b.s. there too.
I did see that CPP calls their modular spindle a 2.5" drop now. I went with the 'classic' spindle when I made my purchase because at the time, the 'modular' spindle was only a 2" drop. They basically keep your truck's front track width the same as the stock drum brake front end, if that's how your truck was originally equipped. So I would think if your truck already had disc brakes stock, the modular spindle would narrow your track width a little more than 1/2".
Adam
Old 01-23-2016, 09:50 PM   #38
invicta455
has me thinking about the BS for my wheels
invicta455 is offline   Reply With Quote
Old 01-24-2016, 02:23 PM   #39
invicta455
insane in the membrane trying to figure it out for my 68 stepside
Old 01-24-2016, 04:02 PM   #40
lolife99
lolife99's Avatar
Backspace is just numbers.
Get out the straight edge and tape measure.
Keith
Old 01-24-2016, 05:18 PM   #41
BossHogg69
motor exploder
BossHogg69's Avatar
It's not that hard, many have done this before you.
Adam
Old 01-24-2016, 08:38 PM   #42
'68 Newtricks
The multi colored truck above with the BOSS rims has 4.75" of backspacing. Just measured. Sorry for taking so long
'68 C10 SWB
'85 K30 Blazer
Old 05-10-2016, 09:44 AM   #43
StupudMunkee
I managed to get the TVS Kit, CPP Drop Spindles, and CPP Big Brake kit installed on my 1970 C10 w/power drums all the way around. All that work and my BS did not make a measurable change.
Problems I ran into:
CPP Master Cylinder (Cannot get properly bled on bench/truck)
CPP Prop Valve (DOA)
Original Axles were warped and discs would not work right (rubbing while rolling)
What I've got:
2002 5.3L w/4l60e
Hotckis TVS Kit
CPP Modular Drop Spindles
CPP Big Brake Kit (F/R)
Moser Axles A30-70GMT4
Wheels: American Racing VF494 20x9.5; 6x5.5; 5" BS
Tires: Nitto 421Q 275/40r20
The truck is dirty as heck, but the stance came out right. Don't look at my bumpers!
Last edited by StupudMunkee; 05-10-2016 at 09:55 AM. Reason: Additional information
Old 05-10-2016, 11:33 AM   #44
BossHogg69
motor exploder
BossHogg69's Avatar
That looks awesome, I'm glad to see it worked out after all that 'head scratchin' & figgerin'!
Call me crazy, but I actually like white bumpers on light/med green trucks.
Adam
Old 05-10-2016, 04:44 PM   #45
StupudMunkee
Thanks! I like the white bumpers too, but they are in pretty bad shape. Will probably have them blasted and repainted body color. That should let the wheels standout without being too blingy.
