Old 02-29-2004, 12:14 PM   #1
polevault1977
Pick'n up the pieces!
polevault1977's Avatar
Cowl question
I am in the process of reworking a 71 cab. This is my first go at a project like this. Question, what is the provisions gm made for the rainwater that enters the cowl area to exit. I know there is the air flappers on both sides, but is that it. So many footwell areas rust out, isn't there anyway it is supposed to get out once it reaches that point?
One other side question. If you go with a smoothed cowl (filled in). How would you get outside air in esp. if you were using a vintage or old air set-up? Recirculate all the time or what?
Any help appreciated. Still learning about these great trucks.
BTW putting rockers in is a piece of cake, cab corners are a bit#$! This was my first go at any body work.
Thanks, Danny
polevault1977 is offline   Reply With Quote
Old 02-29-2004, 02:04 PM   #2
MellowYellow70
Well, if your were to take out the kickpanels, you'd see what loks like a small channell that the accumulated water is suppose to run out of, what it looks to be correct to me anyway.
As far as the smooth cowl, I filled one panel in, but didn't like it much, so I copied the old vacuum actuated chevelle cowl doors, so as more throttle is pressed, I get more inlet air. In theory it works, haven't had it on the road yet though
If patience is truely a virtue, Then I am so screwed
1970 Chevy SWB 331 sbc and all the goodies. Under resurection
2001 Vette
MellowYellow70 is offline   Reply With Quote
Old 02-29-2004, 03:03 PM   #3
barn9
Half a bubble off!
barn9's Avatar
Not sure about the consequences of totally smoothing the cowl as far as air control. But your question brings up another thought that I was just discussing with a couple other board members. Like I told them, the thing I could kick myself for was not eliminating the radio antenna from the cowl. I cuss that thing every time I wash my truck, as well as every time it moves because I cannot keep it tight. Plus, I have thought about a cover for the truck, and it is in the way for that too. The best option for cowls is to put screen under it to keep debris out. And like Mellow said, clean the drain holes out to get the needed water drainage. Good luck on the project, and take some pics and share with us.
Just call me LB.
'71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads.
barn9 is offline   Reply With Quote
Old 02-29-2004, 03:26 PM   #4
polevault1977
Thanks for the responses. I'll be hacking on my footwells next. I'll find the water channel you are talking about. I've just never been there. I'll probably shave the antenna hole. Hadn't really thought about that. Good idea. Not really proud of my cab corners though, i'll post a couple of pics when i get them completely finished. Those things take a lot of massaging to get the fit right. I really admire efab and folks that are good at this. Practices makes perfect. thanks agian, Danny
