Upper control arm spacers
Re: Upper control arm spacers
The thicker ones go on the aft bolts and the flat surface goes outboard. Mine is not apart but appears that the rounded surface may fit into a depression on the crossmember then adjustment shims onto the flat surface. Hope this helps.
Thanks for the info. These are flat on both sides, I noticed the ones that came off the 64 have a dished spacer that pivots on a crowned spacer.
These trucks look to have a crowned rectangular washer that was over these flat ones. |
These slide on first, then the alignment shims, then the rectangle spacers that fit into the control arm shaft. The thick one goes to the rear. I have my frame sitting bare, so I just ran out and snapped a pic for you. Hope this helps.
Thanks very much Jayson! Exactly the info needed to finish putting this crossmember together.
