Old 01-23-2016, 01:36 PM   #1
30 a truck
30 a truck's Avatar
steering column install
I installed my column today. I have the plate on the bottom mounted. I have not put the "U" shaped bracket & rubber on yet. My question is, is this all that holds the column in place? Mine still moves up & down. It is not held tight against the "tooth". What am I missing? I thought the bottom plate held it in place. Am I wrong?
Thanks, Lynn
30 a truck is offline   Reply With Quote
Old 01-23-2016, 02:39 PM   #2
9teen69
9teen69's Avatar
Re: steering column install
You need to mount the U-shaped bracket on the left first.
72 Cheyenne SWB C10 (daily driver)
(Super fake cause I just love the glovebox emblem)
70 Camaro RS (frame-off in pieces)
70 Camaro RS (daily driver backup)
69 Custom LWB C10 (son now drives)
9teen69 is offline   Reply With Quote
Old 01-23-2016, 02:44 PM   #3
chiefcfd
chiefcfd's Avatar
The u-shaped clamp holds the column. Also there is a clamp on the column under the hood. The plate you have mounted only holds the gasket in place.
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 01-23-2016, 04:11 PM   #4
30 a truck
30 a truck's Avatar
Thanks guys. I do not have the "U" shaped piece on the left. Where does it mount?
Old 01-23-2016, 08:55 PM   #5
9teen69
9teen69's Avatar
It mounts before the flat plate, sorry don't a picture.
Not sure if you have all pieces for the engine side but here is a picture of how the column mounts on the engine bay firewall.
You can upgrade to a Premium account and post a WTB add for it.
Also DLTruck1973 sells a lot of misc parts.
http://67-72chevytrucks.com/vboard/s...d.php?t=665662
Old 01-23-2016, 08:57 PM   #6
chiefcfd
chiefcfd's Avatar
It attaches to the brake pedal assembly under the dash.
Old 01-23-2016, 09:54 PM   #7
30 a truck
30 a truck's Avatar
Thanks for the help!!!! I have everything under the hood.
Can't find the "U" bracket anywhere. Can't figure out where it goes either. Could make one if I knew where it goes. Hate to remove the column, might have to. Anyone got a picture of this area???
Lynn
Old 01-23-2016, 10:39 PM   #8
Lancialonnie
On the Brothers trucks website they have a rubber steering column seal and a foam seal listed. My 72 has the rubber seal but no evidence of a foam seal. Did the 72 have a foam seal? Does the foam seal go inside against the firewall? Any pics of one installed?
With all the rain finally in Nor Cal I am finding all kinds of leaks to fix when I'd rather be working on other stuff!
Thanks!
Lancialonnie is offline   Reply With Quote
Old 01-23-2016, 10:58 PM   #9
9teen69
9teen69's Avatar
As Chiefcfd said there are two nut plates on the brake assy.
Old 01-23-2016, 11:03 PM   #10
chiefcfd
chiefcfd's Avatar
I can get you a picture tomorrow if no one has it for you. I guess I was too late. It goes underneath the column an mounts to the 2 holes where the arrows are.
Old 01-23-2016, 11:07 PM   #11
chiefcfd
chiefcfd's Avatar
Thanks!
I have seen those foam seals listed too but have never seen one on a truck. My '72 didn't have one. It had the rubber seal only.
Old 01-23-2016, 11:21 PM   #12
30 a truck
30 a truck's Avatar
Thanks Guys. I got it now. I will make "U" piece tomorrow.
Old 01-24-2016, 06:06 AM   #13
87Skier
87Skier's Avatar
Here is a picture of mine.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
