Old 01-24-2016, 06:22 PM   #11
shrunken66stroker
shrunken66stroker's Avatar
Re: 1965/73 Cheap Build Up
Originally Posted by Strodder View Post
The body and bed aren't even bolted down yet. I have to fab the mounts because of the back half of the frame being from a 73. I want to finish the bodywork that is almost done, then do the frame and mounts. After the frame is done then I'll paint it, then mount everything permanently, wire it and get it running. That's the plan and I'm sticking to it..
You could probably knock all that out in an hour or two. Get to work!
shrunken66stroker is offline   Reply With Quote
