Old 01-20-2016, 01:36 PM   #901
Coach529
Coach529's Avatar
Re: 1949 Chevy 3600 into a daily driver
I hope to have it back on all 4 tires by the end of the weekend.
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 01-20-2016, 02:13 PM   #902
99 to Life
99 to Life's Avatar
Yes I know that is layed out. So if your wheels were on and you are layed out, your saying you are 4" off ground?
From the center of the hub to the ground in this pic, is that the same height as the center of your rim with tire?
Where Im getting at is just maxing out your arms might not be how your truck will lay.
If you remove your bump stop you'd get frame lower and it shouldn't max that balljoint out. On my truck ( I know totally diff) my LCA with bump stop removed, hits the frame
How I set up my truck was body a tad bit lower so I didn't have to dehump the control arm or notch the frame. again, yours is different because your body is mounted in a stock location on a stock frame. I used speedway UCA's.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 01-20-2016, 02:29 PM   #903
Coach529
Coach529's Avatar
Right now the chassis is on jack stands so it is all by the tape measure. I will have to measure it again.....but I came up with 4" before figuring a 28" wheel.
The chassis pretty much bare right now, and when I jack the front suspension up until it starts to lift the frame the bump stop is about 1/4" from hitting. The upper ball joint is not totally bound up, but very stiff.
1949 Chevy 3600
Old 01-20-2016, 02:39 PM   #904
lower50's
lower50's's Avatar
These are the arms I have.
http://www.airassisted.ca/Bolt-in-Ai...r-Control-Arms
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 01-22-2016, 11:10 AM   #905
Coach529
Coach529's Avatar
Originally Posted by lower50's View Post
Those look awesome.......but they will blow my budget!!
1949 Chevy 3600
Old 01-22-2016, 11:57 AM   #906
solidaxel
solidaxel's Avatar
Is that price Canadian or USD?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 01-22-2016, 01:08 PM   #907
lower50's
lower50's's Avatar
Canadian. With the way the dollar is now they are almost free for you guys lol
Right now .71
1951 MG TD
Old 01-22-2016, 01:09 PM   #908
Coach529
Coach529's Avatar
Right now .71
Even at that we are blowing my budget........
1949 Chevy 3600
Old 01-22-2016, 01:45 PM   #909
solidaxel
solidaxel's Avatar
Right now .71
It would be nice to see a list of Canadian Hot Rod or Fabracation company's like Welder Series or Pros Pick or anybody add anything to the list while your dollar is in the cellar.
Last week it was .68.........sorry!
LS 3 4L70E
Old 01-22-2016, 10:33 PM   #910
47 Fasttoys
47 Fasttoys's Avatar
Hey Coach, it's coming together nicely. Something you may want to consider for the battery location is in the fender well behind the front tire. On my '54 and on my '46 I placed it there and it worked very well. On my'46 its been there for 16 years and except for changing the battery 3 times it has been trouble free.
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 01-23-2016, 09:30 AM   #911
Coach529
Coach529's Avatar
Rob
I looked into that a little bit, but I will be running over the frame headers, so that space is occupied.
1949 Chevy 3600
Old 01-23-2016, 11:51 PM   #912
Coach529
Coach529's Avatar
Rear end is almost done.....
1949 Chevy 3600
Old 01-24-2016, 06:28 PM   #913
youngrodder
youngrodder's Avatar
Very cool. Nice work
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 01-24-2016, 06:56 PM   #914
FarmerSid
FarmerSid's Avatar
Nice! Looks compact in there.
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 01-24-2016, 07:31 PM   #915
solidaxel
solidaxel's Avatar
Looks like it was born in there!
LS 3 4L70E
Old 01-24-2016, 09:21 PM   #916
99 to Life
99 to Life's Avatar
dang, lot going on there. nice job
Old 01-24-2016, 09:52 PM   #917
Coach529
Coach529's Avatar
Really busy weekend. Buttoned up most of the rear end install yesterday.
Today I assembled the front end enough to at least make the chassis a roller. It was nice to get it out of the shop and get a good cleaning done.
Rear end sits about perfect. Running boards are about 3/4" off the ground when laid out.
Front end still needs to go down about an inch. Set up right now is completely stock S-10 stuff. I was thinking I would need some drop spindles, but now I think I might be able to get by without.
Bumpers are just touching.....
1949 Chevy 3600
Old 01-24-2016, 10:27 PM   #918
99 to Life
99 to Life's Avatar
really zoning in on it now. the drop spindles might help with your desired ride height. so once your get your bags in there and cups or plates and get the bag aired to a ride height, you'll know if you want to use drop spindles. You can prolly get away without them, if you plate/dehump the lower control arms so the bag sets lower in there.
Old 01-25-2016, 12:12 AM   #919
lower50's
lower50's's Avatar
Great job Coach. The rear end looks factory!!
1951 MG TD
Old 01-25-2016, 12:39 AM   #920
joedoh
joedoh's Avatar
love it! add some camber shims to the front so the front and rear camber is the same laid out and it looks like a toy truck getting squished!
Old 01-25-2016, 09:51 PM   #921
Coach529
Coach529's Avatar
Learning every step of the way.
I am going to order some 2" drop spindles from Speedway and see where I sit. Once I get those in place I can see how much room I have for the bag and know how big to make my cups.
Baby steps I guess.
1949 Chevy 3600
Old 01-25-2016, 09:52 PM   #922
Coach529
Coach529's Avatar
Thanks, I am really happy with how it turned out.
1949 Chevy 3600
Old 01-25-2016, 09:53 PM   #923
Coach529
Coach529's Avatar
I am still on the fence about how much I like the camber the wheels have when aired out.....
1949 Chevy 3600
Old 01-26-2016, 12:32 PM   #924
LEEVON
Moderator
LEEVON's Avatar
SPC makes reasonably priced S10 adjustable upper control arms. In combination with the spindles you should be able to eliminate camber issues.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 01-26-2016, 04:25 PM   #925
Elder Rogue
Elder Rogue's Avatar
I was looking at these.
But I am not bagging mine.
GBody Parts
Elder Rogue is offline   Reply With Quote
