Old 01-24-2016, 06:01 PM   #1
blazercrazy70
blazercrazy70's Avatar
Drive shaft questions any input.
I have a long bed I am getting ready to do a swap on. I am running a 4l60e will the original drive shaft work without changing the input shaft. Would rather run a one piece but sounds as if that could be a problem. Take suggestions
blazercrazy70 is offline   Reply With Quote
Old 01-25-2016, 12:34 AM   #2
jweb
jweb's Avatar
Re: Drive shaft questions any input.
My truck is older but the driveline from my th350 had to be shortened since the 4l60 is longer. The input shaft was the same though.
jweb is offline   Reply With Quote
Old 01-25-2016, 01:50 AM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
If your running a th350 now, the 4l60e output will match up, but I warn people against making the driveshaft a high priority. Your better off doing the swap the way you want it and having a shaft built to match....instead of setting the build around reusing an older part.
Is your original shaft a 2piece, or was there another reason you wanted to re-use the old shaft?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 01-25-2016, 07:44 AM   #4
Keith Seymore
Keith Seymore's Avatar
Originally Posted by BR3W CITY View Post
... but I warn people against making the driveshaft a high priority. Your better off doing the swap the way you want it and having a shaft built to match....instead of setting the build around reusing an older part.
Agree wholeheartedly (said better than I have been able to do it).
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Keith Seymore is online now   Reply With Quote
Old 01-26-2016, 01:20 PM   #5
blazercrazy70
It is a two piece. I.would.rather.have a one piece but some.have said that is to long for a one piece and it may.hit the.crossmember
Old 01-26-2016, 01:58 PM   #6
MalibuSSwagon
Not necessarily. Make the driveshaft a larger diameter if it is longer
MalibuSSwagon is offline   Reply With Quote
Old 01-26-2016, 02:04 PM   #7
brad_man_72
the boat guy
brad_man_72's Avatar
I've built a dozen or so one piece shafts for lwb 67-72s
Not a good idea at stock height w trailing arms. Or if you are laying frame on 24"s. Put the engine and trans as far back as you can if you're worried about length.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 01-26-2016, 02:15 PM   #8
blazercrazy70
It is dropped 4" in the rear.
Old 01-26-2016, 02:58 PM   #9
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Drive shaft questions any input.
My 71 LWB has the 4l80e in it with a 1 piece drive shaft and it has a 3" up front drop and 4" out back. No problems so far in 2 years of driving it.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
