Old 01-26-2016, 07:01 PM   #1
Boilermaker man
Chevelle headers for big block
Hey, I'm new to the forum and read awhile back that guys were using big block Chevelle headers on there lowered trucks, and I installed a new TCI mustang two front end and wondering if these will work with the power steering?
Boilermaker man is offline   Reply With Quote
Old 01-26-2016, 08:03 PM   #2
vidman
vidman's Avatar
Re: Chevelle headers for big block
Yes on the Chevelle headers, Fit great on lowered trucks. not sure about the ferd front-end
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 01-26-2016, 08:51 PM   #3
Boilermaker man
Thanks, so there is enough clearance for the power steering
Old 01-26-2016, 09:10 PM   #4
vidman
vidman's Avatar
power steering works fine with the chevelle headers but the ford stuff i have no idea if things will work..
Old 01-26-2016, 09:40 PM   #5
midniteblues
midniteblues's Avatar
vidman, those fit just like my bbc camaro/nova headers up in the frame.
i see you made a c member mine required the same and it looks almost like yours.
only i have a manual 4spd and z bar mods were required.
op,just goes to show that most will work its just a matter of how much you wanna work with them.
besides the ps lines too the pump i really dont see headers interfearing with a muskrat rack in these trucks. but then again i never did a rack&pinion in one
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 01-26-2016, 10:38 PM   #6
BossHogg69
motor exploder
BossHogg69's Avatar
search "chevelle headers" on this site, many threads and many detailed pics. I'm using chevelle headers on my BB too.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 01-27-2016, 12:10 AM   #7
Boilermaker man
Thanks Adam
Old 05-03-2016, 06:14 PM   #8
hdff
hdff's Avatar
any pics of them installed on your BB? is it an automatic? what kind of other mods were required to get them to fit? I am in the market for some headers right now.....
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach
"Wanda"
Don't argue with idiots, People watching may not be able to tell the difference...
There's someone in my head........But it's not me......
cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394
hdff is offline   Reply With Quote
Old 05-03-2016, 07:46 PM   #9
BossHogg69
motor exploder
BossHogg69's Avatar
Adam
Old 05-04-2016, 04:34 PM   #10
vidman
vidman's Avatar
Some pics for hdff. If you use the Chevelle headers you will have to use an aftermarket or custom trans crossmember or have a custom exhaust made to fit because the collectors exit just in front of the crossmember
Old 05-05-2016, 11:48 AM   #11
hdff
hdff's Avatar
is there enough room to use them with a custom exhaust with a stock trans crossmember? I am not replacing the crossmember. this is how I am piped now. looks like your headers end past the cab frame mount point
"Wanda"
Old 05-05-2016, 04:27 PM   #12
vidman
vidman's Avatar
The chevelle headers will end up 6" or so higher than those so all you will have to do is get some 45 degree bends and make em fit. I ran all my exhaust above the bottom of the frame and through the rear crossmember so you can,t see anything when you look under the truck. If you can,t make your own exhaust you will have to have a shop do it. you will also have very little room for the stock location oil filter. Im using a remote so it was no big deal..
Old 05-05-2016, 10:16 PM   #13
72Cheyenne454
72Cheyenne454's Avatar
I'm running Chevelle mid length headers on mine.
72Cheyenne454 is offline   Reply With Quote
Old 05-06-2016, 04:10 AM   #14
hdff
hdff's Avatar
Why chevelle mid length and not truck mid length?
"Wanda"
