Old 01-26-2016, 07:32 PM   #926
Coach529
Coach529's Avatar
Re: 1949 Chevy 3600 into a daily driver
Originally Posted by LEEVON View Post
SPC makes reasonably priced S10 adjustable upper control arms. In combination with the spindles you should be able to eliminate camber issues.
Those look like a great option.
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 01-26-2016, 07:33 PM   #927
Coach529
Coach529's Avatar
Originally Posted by Elder Rogue View Post
I was looking at these.
But I am not bagging mine.
GBody Parts
Thanks for the link!!
1949 Chevy 3600
Old 01-26-2016, 11:32 PM   #928
Fountain
Coach
I am moving slow but I am watching your every move! Haha. I am attempting the same treatment for the front of my truck. I have everything welded up just waiting for some money to buy my air ride system. What bags are you using? Also thank you so much for posting pics it is a great reference.
Fountain is offline   Reply With Quote
Old 01-27-2016, 12:14 AM   #929
lower50's
lower50's's Avatar
Originally Posted by solidaxel View Post
It would be nice to see a list of Canadian Hot Rod or Fabracation company's like Welder Series or Pros Pick or anybody add anything to the list while your dollar is in the cellar.
Last week it was .68.........sorry!
Sorry I have nothing else to add. Yes it is sad. Good thing I bought everything I needed before the dollar crashed.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 01-27-2016, 09:19 AM   #930
Coach529
Coach529's Avatar
Originally Posted by Fountain View Post
Coach
Cash flow is ALWAYS a problem......that is why I am a little stalled out right now.
Bags are Slam Specialties SS-7.
1949 Chevy 3600
Old 01-27-2016, 10:26 AM   #931
FarmerSid
FarmerSid's Avatar
I hear ya on the cash flow. Always something on the truck you can be doing without spending big bucks.
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 01-27-2016, 11:04 AM   #932
Coach529
Coach529's Avatar
Always something to tinker on......always.....
1949 Chevy 3600
Old 02-03-2016, 08:08 AM   #933
Coach529
Coach529's Avatar
I had about an hour to kill last night between hauling kids around, etc.
I still had the upper ball joint binding issue, so I was curious what it would take to get the running boards on the ground. Seemed like I had three options:
  1. Super travel ball joints
  2. drop spindles
  3. pie cut the UCA
Since pie cutting the UCA was free, and I had spare UCA's in case I screwed up, it was chosen.
A quick Google search and I found a link on a S-10 site.
http://www.s10forum.com/forum/f125/p...l-arms-393969/
20 minutes later my running boards are within a 1/8" of the ground.
This morning I nipped the bump stops off and now it is sitting on the ground.
Tonight I will give them a really good tack, and then remove them to final weld them.
1949 Chevy 3600
Old 02-03-2016, 12:15 PM   #934
99 to Life
99 to Life's Avatar
there ya go, them s10 guys are pretty smart actually.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 02-03-2016, 01:11 PM   #935
Coach529
Coach529's Avatar
Ha. I honestly did not think the cut would provide the relief I need to get to the ground......but it did.
1949 Chevy 3600
Old 02-03-2016, 05:31 PM   #936
lower50's
lower50's's Avatar
Nice fix.
1951 MG TD
Old 02-03-2016, 07:11 PM   #937
youngrodder
youngrodder's Avatar
Looks great, here a nip, there a tuck and now you are laid out. Looks great.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 02-03-2016, 07:45 PM   #938
Coach529
Coach529's Avatar
Marc
Thanks Marc!
1949 Chevy 3600
Old 02-03-2016, 08:50 PM   #939
FarmerSid
FarmerSid's Avatar
Nice! Wow those control arms are at a wicked angle when layed out
C4 IFS & D44 IRS
5.3 HO L33
Old 02-07-2016, 10:16 PM   #940
Coach529
Coach529's Avatar
Another solid weekend........
Bottom of Thunderbird IRS cross member and Danforth cross member final welded and cleaned up ready for paint.
I pulled the cover of the 8.8 and gave it a thorough once over. The fluid was stinky and dirty.....but it looks clean and solid.
I had about 1/4 of can of KBS coatings that I wanted to use on the rear end. The can was a couple years old so I destroyed the cover when trying to get it open. I painted my front UCA's, rear LCA's and center section of the 8.8 as well as a bunch of the frame before the can was empty.
1949 Chevy 3600
Old 02-07-2016, 10:52 PM   #941
youngrodder
Looks good. You should be in good shape for getting it back on the road by spring.
Marc
Old 02-07-2016, 10:58 PM   #942
Coach529
Coach529's Avatar
Marc
I hope so. Still some unknowns I need to figure out:
Motor and tranny (350/350) ran fine when pulled, trying to decided if rebuild or just run it.....or who knows. Too many options.
1949 Chevy 3600
Old 02-07-2016, 11:06 PM   #943
youngrodder
Unless you know/trust the person you bought the motor from I say rebuilt it if it's in your budget. It would be a shame to figure it out later when you are ready to get back on the rd. I have heard of a lot of CL deals gone south on junk motors.
Marc
Old 02-07-2016, 11:08 PM   #944
Coach529
Coach529's Avatar
Marc
I actually ran this motor/ tranny in the truck for the summer, so I am comfortable with it. Just wishing for more HP.
1949 Chevy 3600
Old 02-08-2016, 12:29 AM   #945
99 to Life
99 to Life's Avatar
nice progress. If budget allows, I'd buy up a full roller sbc with vortec heads. 400 bucks running around my parts if you can find them. That is the cheapest route to go for HP and keeping that old school flavor. Get a cheap intake or go with a 2-300 dollar one and that's the biggest expense. Minor head work needs done, and you can get a decent roller cam from GM for $225. again, you can toss money into an sbc and if you take it to the machine shop, good bye budget. or... find a healthy vortec and you'll love the power. Then keep your engine you have now for a back up. Its nice to have a running engine on deck. trust me you or a friend might need it someday! Just run this while you build the new one. anyway, just my take.
Old 02-08-2016, 08:28 AM   #946
Coach529
Coach529's Avatar
1949 Chevy 3600
Old 02-08-2016, 08:37 AM   #947
Coach529
Coach529's Avatar
The motor is a wants vs needs thing. I want big HP.....but ultimately this SBC works great.
When I installed this SBC I could see the cross hatching in the cylinders. Low mileage and I knew 100% of it's history.
Only issues are it leaks a little bit, and the valve seals are shot.
My thoughts were a set of heads to bump up the compression a bit.
http://www.aeroheadracing.com/chevrolet-heads/
Regasket the whole thing and run it. Already have a intake and 4 barrel, headers, cam, etc.........
1949 Chevy 3600
Old 02-08-2016, 09:16 AM   #948
lower50's
lower50's's Avatar
You could always get a motor ready over the summer and swap it next winter.
1951 MG TD
Old 02-08-2016, 10:28 AM   #949
Coach529
Coach529's Avatar
Worst case scenario is the motor in it's current condition gets tossed back in.........which is not the end of the world.
We will have to see what the budget looks like closer to completion......
1949 Chevy 3600
Old 02-08-2016, 10:13 PM   #950
Advanced Design
Advanced Design's Avatar
All the parts look good painted. Coach, same issue we all face isn't it...project creep vs time vs budget vs desired end result and best way to mix all of them to get a project back on the road. You will do well with whichever way you decide to go.
Advanced Design is offline   Reply With Quote
