Old member
Thinking out loud here so:
The system was designed for 4 outlets drivers side, passenger side and the 2 center ones into the single vent. So if you take the hose lose it should be the same amount of air blowing but since the one line is blocked off, it's blowing the same amount of air through less space. That in return makes it feel stronger to the person sitting in the truck.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
| Bookmarks |
