Old 01-28-2016, 12:45 AM   #1
greenmonsterC20
greenmonsterC20's Avatar
Going 5 lug, what brakes should i choose?
So after months of thinking, I've decided to convert my C20 to a Five lug truck with 1/2 ton suspension. I plan on lowering it and doing a ford 9" rear end. Now i have to choose which disc brake kit to go with. I plan on driving this truck very hard when the 383 and Nash 5 speed go in. I was curious what disc brakes everyone is running, pro's and con's of certain kits. Input of any kind will be appreciated.
69 C20 3/4 Ton 350 TH400
63 Buick Rivera 407 Nailhead TH400
greenmonsterC20 is offline   Reply With Quote
Old 01-28-2016, 11:13 AM   #2
brad_man_72
the boat guy
brad_man_72's Avatar
Re: Going 5 lug, what brakes should i choose?
If you have never experienced brake fade I would stick with factory stuff. Gm truck front brakes, I'm sure something from a crown vic would work for the rear, a gm disc disc master cylinder and wilwood adjustable porportioning valve. That should be adequate for towing, very agressive street driving, and any autocross. If you're planning on some track use id keep a set of racing pads in a box for track use because race pads suck on the street.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 02-03-2016, 01:02 AM   #3
greenmonsterC20
Thumbs up Re: Going 5 lug, what brakes should i choose?
Thanks Brad
