01-22-2016, 01:28 PM | #1 |
LS/Vortec Swap ??
I've read a bunch of threads on this swap but don't have a definitive answer to the exhaust manifold question of do I need to replace the stock ones or not? 63 Suburban getting a 2004 Suburban 5.3 package. Is there a variable there depending on what mounting kit I use or.......? Some kits have headers included. Just trying to keep costs down.....thanks!
01-22-2016, 04:35 PM | #2 |
Re: LS/Vortec Swap ??
From my recent LS swap experience the stock truck manifolds will not fit inside the frame rails of a '62 C10, that being said the '63 frame may be wider at that point. I ended up using 2010 Camaro manifolds and I have very little room between the flanges and the frame rails. I did not modify the '62 frame but do have a crossmember swap from a '78 in mine...get the whole donor if you can you can also sell it for parts later.
01-22-2016, 04:50 PM | #3 |
The truck manifolds would not clear the frame on my 66'. I used Trailblazer SS manifolds. I have read some people notching the frame in order to run the truck manifolds. I'm not sure on the kits I used dirty dingo sliders with my stock 66 motor mounts. I did have to use a Camaro oil pan to clear the crossmember.
There is a lot of great information in the LS swap sub forum http://67-72chevytrucks.com/vboard/f...play.php?f=206
It only has original paint once |
01-22-2016, 04:52 PM | #4 |
X-2 on the Dirty Dingo mounts...stock pan cleared my crossmember as well.
01-22-2016, 10:00 PM | #5 | |
Dirty Dingo mounts work well. http://www.azproperformance.com/Dirty-Dingo-67-72-C10/ Posted via Mobile Device |
01-27-2016, 05:37 PM | #6 |
Where did you get the pan for 150 dollars?
01-27-2016, 05:38 PM | #7 |
01-27-2016, 05:38 PM | #8 |
Thank you |
01-27-2016, 10:00 PM | #9 |
Could you post a pitcure of how the muscle car pan fits ? I am curious if it hangs below the crossmember at all with the dirty dingo mounts.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
01-29-2016, 08:50 AM | #10 | |
- Travis |
