#1 | |
Re: Gas tank between the rails 1957 stepside
if i was to do it over, i might try to figure out how to mount the tank under the bottom rail with a one inch spacer...to create more downward angle for the filler... not really sure if that effort would pay off tho. the leaf spring mounts were in the way on the bottom of the frame, and i also knew i didnt want to see the tank under the rear bumper from the back. at the end of the day i like the way i have it mounted because the edge of the gas tank is supporting the tank all the way around and im able to fill the gas tank , just have to fill it slowly.
Frank 1957 Chevy 3100 2000 Silverado z71 SOLD 2012 Ram 1500 Quad Cab 1992 International 4700 |
#2 | |
JT from SC |
]Here's what I did for my 3200 89" long bed:
It's from Tanks, Inc. http://www.tanksinc.com/index.cfm/pa...prod/prd73.htm It's perfect for those that don't want to fill from the bed. What I did for my fill was to cut out the original flange in the cab and found a place on the rear fender with a similar curve and welded the flange in there. ![]() ![]() ![]() ![]() I also tucked this tank in up as high as I could for clearance: |
Hey JT, I'm using a factory inside frame rail tank on my '47. No, it's not the factory frame or a TF but it gives an idea of how low or not so low they hang. 26 gallon, already set for EFI. Tank is on drivers side in front of axle. It's hard to beat GM engineering.
Rob ![]() ![]()
My '47 C.O.E build |
#5 | |
Like the saddle tank install Thanks for sharing JT from SC |
#6 | |
