Old 02-02-2016, 03:27 PM   #1
ScottH
ScottH's Avatar
What is the grade of steering box mounting bolts?
Can anyone tell me what grade the stock mounting bolts for a power steering box would be? I recently installed a new steering box only to have one of the bolts break. So I would like to replace all 4 but not sure if I should use grade 5 or 8. I dont think the bolts I removed were originals as they were 3 different lengths, extra washers, etc.
Any info is appreciated.
Scott
1963 C10 swb fleetside
1966 C10 swb fleetside
1966 GMC G1000 Handi-bus (future project)
1955 Chevy 2 dr. wagon
ScottH is offline   Reply With Quote
Old 02-02-2016, 03:48 PM   #2
rich weyand
rich weyand's Avatar
Re: What is the grade of steering box mounting bolts?
The book says "BOLT 7/16-14 x 1-1/4".
Usually if hardware is grade 5 or 8, it will say so.
I might use grade 5, but not 8.
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 02-03-2016, 01:11 AM   #3
ScottH
ScottH's Avatar
Thanks, from what I've seen online, either a 5 or 8 are used.
Was just hoping for some input from others that have replaced theirs.
Old 02-03-2016, 08:34 AM   #4
74CustomK20
74CustomK20's Avatar
When I did mine and installed the bracing I used 8's. Also used 8's on anything that even remotely come near my truck...
Big Nate
Carp. Local 224. Buy made in the USA!
03 F350 6.0 Daily Race Truck.
79 C70 366 Project Dump.
74CustomK20 is offline   Reply With Quote
Old 02-03-2016, 01:27 PM   #5
rich weyand
The issue with using grade 5 and grade 8 bolts is one of torque specs. You need to torque bolts to where they deform a bit in order for them to stay tight. To do that with grade 5 and especially grade 8 bolts requires that they be torqued much more.
From this chart, a 7/16-14 (which is 7/16 NC) in grade 2 takes 24 ftlbs, in grade 5 takes 37 ftlbs, and in grade 8 takes 52 ftlbs of torque to be considered torqued up. The question then is, what kind of threads are you torquing it into, and can they take that?
It's not just a simple issue of "more is better".
https://www.boltdepot.com/fastener-i...ed-Torque.aspx
Rich Weyand
1978 K10 RCSB DD.
Old 02-03-2016, 02:19 PM   #6
ScottH
ScottH's Avatar
Thanks guys, appreciate the info.
Gonna go with grade 5 bolts.
Old 02-03-2016, 02:59 PM   #7
65 C20
Captain Fab has been making and selling power steering brackets for years and supplies grade 8 bolts in his kits.
I am just saying.
You say you have already had one break, why go with cheaper bolts ?
65 C20 is offline   Reply With Quote
Old 02-03-2016, 03:24 PM   #8
hatzie
Moderator
hatzie's Avatar
I am just saying.
Boy... Folks don't listen do they.
It's not a question of cheaper or more expensive... or even Mores' law.
The threads in the Cast Iron steering box may not put up with the torque necessary to properly tighten Grade 8 bolts.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 02-03-2016, 03:56 PM   #9
nvrenuf
Mark me as another non listener...
I used grade 8 bolts. Also I went slightly longer (1/2" maybe, can't remember) on 3 of them and put Stover (pinch type) lock nuts, the 4th bolt doesn't come thru the casting.
John
'91 Blazer, full top, bbc, 4spd, Doubler, 1 tons, 40's
nvrenuf is offline   Reply With Quote
Old 02-03-2016, 05:20 PM   #10
rich weyand
Nope. The mis-use and over-use of hardened fasteners is fairly common. With experience, you learn that the most common cause of fastener failure is failure to torque them to specification.
Rich Weyand
1978 K10 RCSB DD.
