Old 01-25-2016, 09:42 AM   #551
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Lost My 65
As you can see, hoses are rubber and not buttoned down or routed logically.
I'm just getting everything together so I can get it mobile again. Then I'll go back and put things together nicer.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 01-25-2016, 09:45 PM   #552
LostMy65
LostMy65's Avatar
Re: Lost My 65
Got the column mounted up.
Also cut the shaft for shortening for the power steering gear box.
Old 01-25-2016, 10:53 PM   #553
LostMy65
LostMy65's Avatar
Re: Lost My 65
Okay, I need a little help.
I slipped on the blinker switch housing -lining it up with the tabs this blinker switch housing on.
But what keeps it from rotating?
Old 01-26-2016, 11:26 AM   #554
LostMy65
LostMy65's Avatar
Re: Lost My 65
What I'm asking is how does that housing keep from turning back off? Is there something I'm missing that's supposed to keep it from coming back off?
Old 01-26-2016, 09:30 PM   #555
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
Re: Lost My 65
When you screw the turn signal switch on it gets locked in place.
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline   Reply With Quote
Old 01-26-2016, 09:38 PM   #556
LostMy65
LostMy65's Avatar
Re: Lost My 65
Thank you.
Old 01-27-2016, 08:33 PM   #557
LostMy65
LostMy65's Avatar
Re: Lost My 65
Got the shifter linkage hooked up to the column and shifted it through the gears to make sure P-R-N-D-L2-L1 lined up with the shifter lens.
All is good.
Old 01-30-2016, 09:27 PM   #558
LostMy65
LostMy65's Avatar
Re: Lost My 65
Got most everything hooked back up.
Get my seats back in the cab, bleed the brakes and then
hopefully by Tuesday or Wednesday, I'll take it for a short test drive on the back roads.
Old 02-02-2016, 06:13 PM   #559
LostMy65
LostMy65's Avatar
Re: Lost My 65
So close.
Gotta stop and eat a sandwich, then I figured I'd better hook up the emergency brake cables first. That's all I need to do to take it for a quick spin.
On a side note ; I hooked up a vacuum gauge. I'm glad to see I'm actually getting 15 at idle. Last time I checked, I seem to remember only about 10 or 11.
Old 02-02-2016, 07:26 PM   #560
66-PMD-GMC
66-PMD-GMC's Avatar
Re: Lost My 65
Sooooo....
Are you out driving around?
Projects..
440CID 2X4 Pontiac
Old 02-02-2016, 08:33 PM   #561
Re: Lost My 65
Originally Posted by 66-PMD-GMC View Post
Sooooo....
I guess since he don't have to shift now he'll never return from the drive.
Old 02-02-2016, 09:09 PM   #562
LostMy65
LostMy65's Avatar
Re: Lost My 65
Oh Yes! Man does it shift nice!
Perfect stall on the Torque Converter.
Totally Stoked!
I have a video I'll try to upload later.
Old 02-02-2016, 10:02 PM   #563
66-PMD-GMC
66-PMD-GMC's Avatar
Re: Lost My 65
Projects..
440CID 2X4 Pontiac
Old 02-02-2016, 10:23 PM   #564
Re: Lost My 65
What stall are you running?
Old 02-02-2016, 11:59 PM   #565
LostMy65
LostMy65's Avatar
Re: Lost My 65
I don't know. I got a great deal for the Th350 with the converter off CL.
It's a Summit with a B&M Shift Kit.
Old 02-03-2016, 12:02 AM   #566
LostMy65
LostMy65's Avatar
Re: Lost My 65
I have the floor hump out, so there's lots of clanging and clunking.
https://youtu.be/TsM-IeYaHME
Old 02-03-2016, 11:52 AM   #567
66-PMD-GMC
66-PMD-GMC's Avatar
Re: Lost My 65
Tie all that stuff down, install the tunnel cover and hood and get out there and do a big smokey burnout for us..
Projects..
440CID 2X4 Pontiac
Old 02-03-2016, 09:01 PM   #568
LostMy65
LostMy65's Avatar
Re: Lost My 65
Picture from yesterday.
Old 02-03-2016, 09:09 PM   #569
Re: Lost My 65
Old 02-03-2016, 09:09 PM   #570
LostMy65
LostMy65's Avatar
Re: Lost My 65
Got the low Hump bolted in.
Then put floor pad down, then the rubber floormat.
I'll see if I can get the hood on tomorrow.
Old 02-03-2016, 09:57 PM   #571
Re: Lost My 65
Looking good man!
Old 02-03-2016, 10:17 PM   #572
LostMy65
LostMy65's Avatar
Re: Lost My 65
Thank you.
I'm just busting to get it all back together.
I'll have a lot of misc details that I'll need to go back and button down,
but that's okay, I'll take care of those things when the weather gets nice.
Old 02-04-2016, 12:46 AM   #573
66-PMD-GMC
66-PMD-GMC's Avatar
Re: Lost My 65
You're doing a great job.. stick with it..
Show us some tire smoke..
Projects..
440CID 2X4 Pontiac
Old 02-06-2016, 11:59 PM   #574
LostMy65
LostMy65's Avatar
Re: Lost My 65
Drove it around some.
(Sorry to disappoint you, Chris, but I won't be doing any purposeful burnouts anytime soon.)
So, driving it around today I notice a vibration that fades in and out. It's not a consistent
vibration at a given speed. It's the worst at about 38 mph. But it's not a consistent vibration at 38 mph, but rather; it resonates in and out while driving at 38 mph.
I'm currently reading up on the issue.
Threads I've considered so far:
http://67-72chevytrucks.com/vboard/s...d.php?t=694626
http://67-72chevytrucks.com/vboard/s...d.php?t=522180
Old 02-07-2016, 09:12 AM   #575
66-PMD-GMC
66-PMD-GMC's Avatar
Re: Lost My 65
Awww gheezzz..
O...k...
Projects..
440CID 2X4 Pontiac
