02-02-2016, 12:55 AM | #1 |
4x4 LS Swap VSS
I am gather part to put a 6.0/4l80 in the 72 4x4 I have and was wondering how people have gotten the VSS on to their trucks. I have seen several options, have a sensor put in the 205 ,find the unicorn that is a 90-91 241 passenger side drop with the vss, or the sensors that screw into the speedo cable hole (the ones i have seen don't seem to put of the correct signal). ANy help on what i need to get fro parts would help.Thanks.
02-02-2016, 05:32 AM | #2 |
Re: 4x4 LS Swap VSS
the best option is a 2wd 4l80e because the tone ring is already installed in the trans. take the tailhousing off and bolt up the 205.
1971 K30 burb carbed LS6 th400 np205 d70f 14bff 4whl discs lifted 35 bfg's 1994 k3500 rcsb trophy truck ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's 1998 K3500 rclb ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's 1999 k3500 crewcab dually 4x4 496ci 4l85e bw4401 9.25ifs 14bff g80 6" lift 37 bfg's |
02-02-2016, 09:58 AM | #3 | |
Boosted Member
Re: 4x4 LS Swap VSS
I have the same trans in the '69, and also went to the trouble to track down an NP241 with VSS...well I never ended up hooking up the VSS in the t-case...just runs off the trans VSS, and works great.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
02-02-2016, 05:06 PM | #4 |
Re: 4x4 LS Swap VSS
02-02-2016, 11:44 PM | #5 |
Re: 4x4 LS Swap VSS
you need the np205 that came off of a th400. it has the same bolt pattern as the 4l80e and they are both 32 splines so it is a bolt together ordeal. th400 and 4l80e share alot of components mostly just being the 4l80e obviously has overdrive. but output shaft and bolt pattern are the same.
