Re: Daddyjeep Hauler - 85 K30 crew cab short bed
So I finally messed with the truck and little tonight. I took the two, yes two, bolts that held on the fifth wheel hitch on out so I could yank it out of the bed. I can't believe someone hauled trailers with two 1/2 inch bolts. I also investigated things a little and got a pic of this.
[IMG] [/IMG]The bed is really nice for this part of the country. Just look at that floor. [IMG] [/IMG]Here she is in all her rusty glory. Hopefully I can make some steady progress now. [IMG] [/IMG]I tried unbolting the bed mounting bolts and to my surprise they actually turned...for a little while. The head started turning in the bed. On to plan B. What is the best method to remove them? I was thinking drilling out the heads would probably be the easiest.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
| Bookmarks |
