![]() Join Date: Sep 2002
What is the grade of steering box mounting bolts?
Can anyone tell me what grade the stock mounting bolts for a power steering box would be? I recently installed a new steering box only to have one of the bolts break. So I would like to replace all 4 but not sure if I should use grade 5 or 8. I dont think the bolts I removed were originals as they were 3 different lengths, extra washers, etc.
Any info is appreciated. Thanks Scott
1963 C10 swb fleetside 1966 GMC G1000 Handi-bus (future project) 1955 Chevy 2 dr. wagon |
Re: What is the grade of steering box mounting bolts?
The book says "BOLT 7/16-14 x 1-1/4".
Usually if hardware is grade 5 or 8, it will say so. I might use grade 5, but not 8.
Rich Weyand 1978 K10 RCSB DD. |
Thanks, from what I've seen online, either a 5 or 8 are used.
Was just hoping for some input from others that have replaced theirs.
When I did mine and installed the bracing I used 8's. Also used 8's on anything that even remotely come near my truck...
Big Nate Carp. Local 224. Buy made in the USA! 03 F350 6.0 Daily Race Truck. 79 C70 366 Project Dump. |
The issue with using grade 5 and grade 8 bolts is one of torque specs. You need to torque bolts to where they deform a bit in order for them to stay tight. To do that with grade 5 and especially grade 8 bolts requires that they be torqued much more.
From this chart, a 7/16-14 (which is 7/16 NC) in grade 2 takes 24 ftlbs, in grade 5 takes 37 ftlbs, and in grade 8 takes 52 ftlbs of torque to be considered torqued up. The question then is, what kind of threads are you torquing it into, and can they take that? It's not just a simple issue of "more is better". https://www.boltdepot.com/fastener-i...ed-Torque.aspx
Thanks guys, appreciate the info.
Gonna go with grade 5 bolts.
Captain Fab has been making and selling power steering brackets for years and supplies grade 8 bolts in his kits.
I am just saying. You say you have already had one break, why go with cheaper bolts ? |
#8 | ||
Moderator
![]() Join Date: Oct 2008
![]() ![]() ![]() It's not a question of cheaper or more expensive... or even Mores' law. The threads in the Cast Iron steering box may not put up with the torque necessary to properly tighten Grade 8 bolts.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
Mark me as another non listener...
I used grade 8 bolts. Also I went slightly longer (1/2" maybe, can't remember) on 3 of them and put Stover (pinch type) lock nuts, the 4th bolt doesn't come thru the casting.
John '91 Blazer, full top, bbc, 4spd, Doubler, 1 tons, 40's |
Nope. The mis-use and over-use of hardened fasteners is fairly common. With experience, you learn that the most common cause of fastener failure is failure to torque them to specification.
