Old 01-31-2016, 05:52 PM   #1
lyrikz
PITbut
lyrikz's Avatar
installing aftermarket seats. Weld in or bolt in?
Putting a set of seats in my blazer that I had to make custom brackets for. Can I weld in the brackets to the floor or do I have to bolt them in? Is one better then the other.
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
lyrikz is offline   Reply With Quote
Old 01-31-2016, 06:17 PM   #2
67ChevyRedneck
67ChevyRedneck's Avatar
Re: installing aftermarket seats. Weld in or bolt in?
Best of both... Weld support plates with welded on nuts under the floor so you can bolt them in.
If you ever change your mind you just unbolt them.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 01-31-2016, 06:28 PM   #3
davepl
davepl's Avatar
For crash safety they should be into the reinforced area, with through-bolts and washers. Wouldn't hurt to weld them too, but I wouldn't go with a weld alone. Unless you're a pro and can x-ray it, or are sure you'll never be in an accident...
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 01-31-2016, 07:48 PM   #4
brad_man_72
the boat guy
brad_man_72's Avatar
Bolt in.. unless you can weld through carpet.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 01-31-2016, 09:25 PM   #5
lyrikz
PITbut
lyrikz's Avatar
Well no carpet.
So a bolt and washer is better then a full weld.
Welp fun fun.
and sold.
Old 01-31-2016, 10:00 PM   #6
truckster
truckster's Avatar
I welded my brackets so they fit my original reinforced mounting points. I used grade 8 hardware to bolt them in.
truckster is offline   Reply With Quote
Old 02-01-2016, 11:30 AM   #7
lyrikz
PITbut
lyrikz's Avatar
I plan on tacking them in, then running a bolt through the whole assembly with a plate on the bottom if i can access it..
I will find out tomorrow.
and sold.
Old 02-02-2016, 07:20 AM   #8
Grumpy old man
Grumpy old man's Avatar
Don't ever weld seat tracks to the floor with or without bolts . The constant fretting from the seat rocking forward and back will eventually crack/tear the sheet metal and it's just not safe in any type of crash . Bolts and reinforcement plates NOT just a few washers ! are the way to go . You have to remember these are trucks with 50 year old technology and I can't even begin to count the number of people I know of who had serious face/head injuries from just a lap belt and no headrest that WERE installed correctly . Sit in your truck and get belted in then lean forward as far as you can and then you'll understand what I'm saying ! It's also one of the reasons seats were bolted together so they wouldn't fold forward and windshields stopped being gasketed in ,People where getting launched thru the windsheild in a serious crash .My brother in law died sitting at a stop light and was hit from behind ,His face hit the steering wheel and resulted in massive facial injuries and instantaneous death
https://en.wikipedia.org/wiki/Fretting
This is also why it's better to use real gaskets rather than rtv sealants alone that will eventually leak
I can't stress enough how important these things are . I see guys daily drop their truck and add 1,000's of dollars of suspension work and a 500 hp ls engines and not consider they are bolting all of that to a 50 year old frame that already has the familiar "Chevy twist" then jump into the bench seat with a lap belt and Turn it loose ?
Old 02-02-2016, 01:36 PM   #9
cypressbog
Go Pack Go!
I wish this site had a like button like facebook. Grumpy old man is spot-on!
cypressbog is offline   Reply With Quote
Old 02-02-2016, 02:08 PM   #10
Mduma72
Absolutely he is right bolt only.
On an other note can you use bench seat brackets were bucket seats would go hard time finding bucket seat tracks wondering if bench tracks would bolt up. slider not an issue finding electric seats. If any one knows thanks .
Mduma72 is offline   Reply With Quote
Old 02-02-2016, 05:26 PM   #11
lyrikz
PITbut
lyrikz's Avatar
I was committed to the weld in and then i got in the truck and moved around a bit. The floor flexes a wee bit. After time that will definitely crack. They are just tacked right now. So im going to run bolts through the bracket/mount and then floor plates under the truck. Only issue i can see with that right now is my rocker box is DIRECTLY under the outside seat mounts. Do i have to cut a hole in that to mount the plates?
I was thinking cutting a hole in the rocker, welding in a plate with nuts, rust protect everything, then refill the hole on the rocker box and call it good. It would be similar to whats on there now, just way bigger nuts and base plate.
Any better ideas?
and sold.
Old 02-02-2016, 08:11 PM   #12
Grumpy old man
If your seat tracks are all the way out to the rockers somethings wrong ? Have you tried closing the doors with the seat in position yet ? what seat are you trying to mount ? Pictures ?
Old 02-02-2016, 08:27 PM   #13
Mduma72
Bench tracks
I'm not sure if your reply was to me or not but was wondering if I can use bench tracks to fit in the spot were bucket seat tracks would fit . Wanting to put bucket seats in thanks
Kickin c 10s
Old 02-02-2016, 08:40 PM   #14
lyrikz
PITbut
lyrikz's Avatar
GOM, they are located above the rocker boxes, it's a blazer.
I have to remove the rockers to replace anyways. I will put the seat plates in at that time.
and sold.
Old 02-02-2016, 08:43 PM   #15
Grumpy old man
The distance from the center of the steering wheel should be the same for buckets and a bench seat so they should mount using the outer seat track mounts already in the floor . Easy way to do this with any buckets you want to mount is to take a center line down thru the center of your steering wheel and it should be in the center of your seat that your trying to mount . NOTHING is worse than trying to drive a truck with the drivers bucket seat not centered with the steering wheel .
Old 02-02-2016, 08:44 PM   #16
truckster
truckster's Avatar
Maybe I should have been clearer. I fabricated brackets on the seats (that's the welding part) and then bolted those brackets to the original mounting points with grade 8 hardware.
Old 02-02-2016, 10:24 PM   #17
doo142
doo142's Avatar
This is the only way to go, any drilling and plating would be a hack, no insult intented, peace!!
doo142 is offline   Reply With Quote
Old 02-02-2016, 11:21 PM   #18
Mduma72
Talking Re: installing aftermarket seats. Weld in or bolt in?
Hey thanks. Makes life a lot easer now just get tracks perfect thanks again for the help.
Kickin c 10s
Old 02-03-2016, 06:47 PM   #19
lyrikz
PITbut
lyrikz's Avatar
I am removing my floor panel, installing a new unit and then plating and running new bolts. Safer. Also, the amount of flex in those factory bolt holes now is scary. Stating that running a better mounting system/safer mounting area is hack job is ridiculous.
and sold.
Old 02-03-2016, 06:48 PM   #20
lyrikz
PITbut
lyrikz's Avatar
Thanks for the advice on not welding. Appreciate the response.
and sold.
