Old 02-03-2016, 07:33 PM   #626
Advanced Design
Advanced Design's Avatar
Re: My 52 GMC Build
Lower that was a nice mod. What wiper motor is that?
Advanced Design is offline   Reply With Quote
Old 02-03-2016, 08:56 PM   #627
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: My 52 GMC Build
Originally Posted by lower50's View Post
This morning I hooked up my 3 in one gauge (EGT, Trans temp, Boost). I also got my Transmission controller plugged in and mounted. The switch is for the 2 shifting programs I can have loaded.
Attachment 1494572
Attachment 1494573
Very nice! Your trans controller is pretty neat. Keep the boost below 20 so you can enjoy it for a long time!
Ryan
1969 Chevy milk truck
Old 02-03-2016, 09:23 PM   #628
99 to Life
99 to Life's Avatar
Re: My 52 GMC Build
making it look easy
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 02-03-2016, 09:45 PM   #629
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Thanks It's the rear wiper from a '97 s-10 blazer
Thanks Diesel I'm going to run max 15psi.
Originally Posted by 99 to Life View Post
making it look easy
You know it's not
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 02-04-2016, 04:09 PM   #630
lower50's
lower50's's Avatar
Re: My 52 GMC Build
As of this morning I have working wipers, tail lights and brake lights. For the wiper motor arm I used 1/2"X1"X5" but 1/2"X3/4"X3" would work. The center hole is 8mm with a 10mm step 3/4 of the way through. That is the profile of the wiper motor shaft. The pivot holes are 5/16" and I used a 5/16"X 1.5" bolt so the arm will pivot on the shoulder, then double nut. 2 vids of wipers.
http://vid51.photobucket.com/albums/...psc2f1reak.mp4
http://vid51.photobucket.com/albums/...pso8qptf7g.mp4
This is my first drawing not what I ended up with exactly. It's close.
1951 MG TD
Old 02-04-2016, 04:19 PM   #631
iowaboynca
iowaboynca's Avatar
Re: My 52 GMC Build
That's slick
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 02-04-2016, 04:48 PM   #632
JJorgensen52
Simple? What's simple?
JJorgensen52's Avatar
Re: My 52 GMC Build
This is great info! Is that center hole tight enough to interfere with the splines on the motor shaft, or are you just relying on the end nut to keep it tight enough?
CURRENT
'50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build
'63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos
'66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos
'69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!)
'72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh
'99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily)
'99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs)
SOLD
'71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder)
JJorgensen52 is offline   Reply With Quote
Old 02-04-2016, 05:39 PM   #633
Chance48
Re: My 52 GMC Build
I need to copy that instead of buying the 150 buck replacement.....hmmm, nice work amigo!
SHAKE N BAKE BABY, SHAKE N BAKE....
http://67-72chevytrucks.com/vboard/s...d.php?t=686729
Chance48 is offline   Reply With Quote
Old 02-04-2016, 06:17 PM   #634
FarmerSid
FarmerSid's Avatar
Re: My 52 GMC Build
That's slick! That's will help out a lot of us! ��
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 02-04-2016, 07:01 PM   #635
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Thanks guys I was dreading this part but it worked out quite nice. I had trouble finding info on how to do this. So I hope I explained it well enough. For $35 for the motor from a wrecker it's a great deal.
JJorgensen52 Bit of both the 10mm hole is drilled as a pilot for the arm and the angle down to the 8mm will grip on the splines. Then the nut will hold it as well. I ground a 10mm drill so it had a bigger angle on the tip.
1951 MG TD
Old 02-04-2016, 08:55 PM   #636
joedoh
joedoh's Avatar
Re: My 52 GMC Build
super dope! what a great mod. I hate to admit I threw away a blazer rear gate before pulling the motor.
Old 02-05-2016, 04:13 PM   #637
lower50's
lower50's's Avatar
Re: My 52 GMC Build
As of now I have gauges that as I can tell work and all my LED dash lights work.
I'm going to plug the block heater in tomorrow morning and fire the truck up. The only gauge that is not hooked up yet is boost.
1951 MG TD
Old 02-05-2016, 04:19 PM   #638
4DSEVEN
4DSEVEN's Avatar
Re: My 52 GMC Build
Looks great man!
4DSEVEN is offline   Reply With Quote
Old 02-05-2016, 04:31 PM   #639
JJorgensen52
Re: My 52 GMC Build
You and me both
Lowers, the truck is looking great! How soon will you be rolling?
CURRENT
SOLD
Old 02-05-2016, 05:18 PM   #640
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Thanks 4DSEVEN
[QUOTE=JJorgensen52;
Lowers, the truck is looking great! How soon will you be rolling?[/QUOTE]
Thanks. I think first test drive will be middle of April weather permitting. I have a 2 week holiday trip coming up in 2 weeks, so after that I should be able to pull it out of garage to the driveway for some testing.
1951 MG TD
Old 02-08-2016, 09:11 AM   #641
lower50's
lower50's's Avatar
Re: My 52 GMC Build
On Saturday my boys came out to the garage with me and they started the truck after a coin flip. I'm happy to say all the gauges work.
Here is a vid
http://vid51.photobucket.com/albums/...psqaksapv7.mp4
1951 MG TD
Old 02-08-2016, 10:56 AM   #642
99 to Life
99 to Life's Avatar
Re: My 52 GMC Build
congrats
Old 02-08-2016, 02:25 PM   #643
YahamaR1
YahamaR1's Avatar
Re: My 52 GMC Build
Looking good that dash..
Nice work on the wipers
YahamaR1 is offline   Reply With Quote
Old 02-08-2016, 02:43 PM   #644
84blaze
Re: My 52 GMC Build
Ill be looking for one of the motors. Seems like an easy way to do it.
84blaze is offline   Reply With Quote
Old 02-08-2016, 09:25 PM   #645
65sub
65sub's Avatar
Re: My 52 GMC Build
Truck sounds real good. Warm weather is coming soon.
Dale
My suburban's Twisted Little Sister
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 02-09-2016, 08:27 AM   #646
lower50's
lower50's's Avatar
Re: My 52 GMC Build
congrats
Thanks 99
Thanks R1 I'm happy with how it turned out
It was much easier than I was expecting.
Thanks I know I cant wait. I'm really hoping for an early spring.
1951 MG TD
Old 02-09-2016, 09:28 AM   #647
Chance48
Re: My 52 GMC Build
I love the sound of them old 7.3's. Can't wait to hear it run by on the road.
Old 02-09-2016, 09:56 AM   #648
lower50's
lower50's's Avatar
Re: My 52 GMC Build
You will my friend you will...... Well in a video at very least.
1951 MG TD
Old 02-10-2016, 09:48 PM   #649
Dieselwrencher
Re: My 52 GMC Build
Great work! Is that your radio below the dash with the pic of the GMC? Also, is the pyro/boost gauge a glow shift? I've considered getting one of their fuel pressure gauges but I know they have had big issues in the past with being bad.
Ryan
Old 02-10-2016, 10:02 PM   #650
Advanced Design
Re: My 52 GMC Build
Just caught the video. Great sound and a ton of cool features in your truck!
bagged, build, diesel, gmc, hot rod
