12-31-2014, 01:48 PM | #26 | |
Re: Gas tank relocation
You can see here that I welded it to the 2 pipes that are used for the tank mount. Those are standard 1/2" black pipe and are plenty strong so there's no concern there. I will have to remove the tank when I install the bed wood. No big deal to me. There's still room for mounting bolts but I may have to trim the bolt ends off. |
12-31-2014, 02:13 PM | #27 | |
Frank 1957 Chevy 3100 2000 Silverado z71 SOLD 2012 Ram 1500 Quad Cab 1992 International 4700 |
12-31-2014, 02:56 PM | #28 | |
Btw, I don't remember who gave the tip to me but it was a good one. Since I was putting in rear cab corners on this truck, the parts I cut off gave me a perfect contour to make a patch from for the patching filler hole. |
12-31-2014, 03:03 PM | #29 |
Here is mine, 19 gallon from Yogies. Because of the fleetside spears the access is low and hose runs relatively flat so I will need to be careful when filling. The tank is designed for step side so cross sill needed modified, I beefed it up with 1" angle on the front side. Door is from a 90's Dodge caravan, chosen for the inside release and matching the curve of the bed side. Release is inside cab, POL had the sending unit with OHM value to match original gauge. Bolts to bottom of frame so I can remove without taking the bed off.
01-31-2015, 12:56 AM | #30 | |
i just got my tanks inc mustang tank.. not sure if i have to do the same to my sill, or if the filler will be just below it?
01-31-2015, 12:16 PM | #31 |
Not to change the direction of the thread, but for general information, that odd cross member goes in position three which is toward the rear of the spring. It seems to be a common mistake to put it over the axle in position two.
01-31-2015, 12:20 PM | #32 | |
And is that info the same for a long bed too? |
01-31-2015, 02:46 PM | #33 |
I wasn't speaking to anyone in particular, just noticed that both of the last couple of pics didn't show that different bed cross member in the number three position. From what I see in the FAM, that odd cross member is only used on short bed trucks where it is positioned above the rear of the spring. Doesn't look like long bed trucks use that different cross member at all. The main reason that I even commented is that I found out after I bought my FAM that my cross members are not in the correct sequence either.
02-02-2015, 01:35 PM | #34 |
Some great work in this thread!
Wish I met you guys before I did all this myself years ago. I posted a thread about my tank relocation here. I did have my original fuel fill neck in the cab removed, mostly for aesthetics reasons, however with a locking gas cap, this could be converted into a unique stash box location for small items like spare ignition key, house keys, cash, etc.
Déjà vu. It's that feeling you get when you hit your thumb with the hammer a second time '59 Chevy 3100 Stepside |
02-02-2015, 02:09 PM | #35 | |
Never thought of that before. |
02-02-2015, 06:09 PM | #36 |
unless the locking cap key is on the same key ring
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
02-03-2016, 10:19 PM | #37 |
Mistake
Duplicate post. Last edited by roger55; 02-03-2016 at 10:30 PM. |
