Old 03-01-2004, 09:28 PM   #1
1972C10
1972C10's Avatar
1993 1Ton 4WD Questions
A friend of mine is lookin into getting a new truck and selling his old one wich is a 1993 silverado 1ton 4wd with a 454
I dont know a whole lot about these years there kinda in between what i know of Does it have the 4L80E?
What kinda transfer case does a truck like this have?
Its got the towonda 454 Not the average he ordered it with this motor supposed to be better steel and steel crank and whatnot
What kinda front end does it have im assuming the rear is a 14 bolt
We Belive it to have around 4.11 gears it tachs up about 3400 in third at 70
Are these trucks very difficult/Expensive to lift up Say 6-8 inches and still have good pinion angle?
Ive never had any experience lifting the front of these IFS trucks THe back should be as simple as blocks or springs or hangers but the front im not certain.
Any info on the subject would be greatly apreciated
1972C10 is offline   Reply With Quote
Old 03-01-2004, 10:22 PM   #2
1FaastC10
1FaastC10's Avatar
probably got a TH400 if its turning those kind of RPMs. case i believe is a 241C
1FaastC10 is offline   Reply With Quote
Old 03-02-2004, 01:26 AM   #3
1972C10
1972C10's Avatar
Its an overdrive of some kind im not sure if its a 4l80 or what 4th gear is kinda messed up works sometime sometime dont .. Something electrical
\ Ive never had any expeirecne with these year models and i didnt crawl under it I can tell the difference just havent been under the truck
Old 03-02-2004, 03:01 AM   #4
1tonswb
1tonswb's Avatar
Your front pinion angle doesnt matter because your diff does not move. When you lift a ifs chevy its all drop down brackets. I lift these trucks daily. The ease of install depends on which kit you buy. Pro comp and superlift are a major pain to install. The fabtech kits are fairly easy (depending on your mechanical ability and tools you have). 6 inch kit is roughly around $2000.00. Add on the price of install and alignment and your lookin at $2700.00. Then wheels and tires.......$1000.00 easy. So by the time your done your into the lift and tires for about $4000.00.
1tonswb is offline   Reply With Quote
Old 03-02-2004, 04:28 AM   #5
1969 GMC
1969 GMC's Avatar
the tranny is a 4l80e, or at least it SHOULD be in a '93.
$4k for an IFS lift? Thank goodness for solid front axles.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
