Closed Thread
Old 02-03-2016, 12:19 PM   #3226
73737373
Re: What did you do to your truck today? Chapter II
Originally Posted by tommys72 View Post
Drove it out to the property Saturday to check on and feed the cow.
Looks like something right out of a Chevy ad from Life Magazine. Cool
73737373 is offline
Old 02-03-2016, 12:36 PM   #3227
tommys72
tommys72's Avatar
Thanks, it turned out good.
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline
Old 02-03-2016, 03:54 PM   #3228
74baggedbug
In the middle of this
74baggedbug is offline
Old 02-03-2016, 04:08 PM   #3229
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
You all shamed me into going out, removing the cover, cleaning Rat up a little, and starting her up.
Operating temp, a few wipes inside, and back into the house for me.
Tough day....
Gotta get out there and switch out my electric fuel pump...
And, oh, probably time for a starter.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 02-04-2016, 10:21 AM   #3230
73737373
Baby steps..... At some point, the truck had a camper shell on it and someone had removed the backglass and installed some sort of "seal" (for lack of a better term) as a "go between" between the cab and the now covered bed. The camper shell was removed and the backglass had to be reinstalled, but when they did, they used the solid rubber seal and not the one w/the chrome trim. A lot of words to let you know I removed the backglass, cleaned up the window opening and reinstalled backglass using a chrome trim gasket, which BTW, was an original, at least 43 years old and it went in like a hot knife thru butter. Maybe an hour job....
73737373 is offline
Old 02-04-2016, 10:23 PM   #3231
Possmguts
Possmguts's Avatar
Oh boy... fun fun... cant wait to get to this point (insert sarcasm here)
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline
Old 02-06-2016, 08:07 PM   #3232
Possmguts
Possmguts's Avatar
Got started on the driver side door bottoms today... Hope to get about done tomorrow with this one. What a PITA! lol.. I forgot to drill the hinge bolt holes.. That's gonna be fun...
Old 02-06-2016, 11:10 PM   #3233
68 Stepper
Started my disc brake conversion.
68 Stepper is offline
Old 02-06-2016, 11:30 PM   #3234
AKC
AKC's Avatar
See my last post...
AKC is offline
Old 02-07-2016, 12:27 AM   #3235
Russ.W.
Russ.W.'s Avatar
A few weeks back I noticed my ECE drop spindles had accumulated some surface rust whilst sitting around waiting for me to use them
Since not much else can be done to the truck at the moment, I attacked the spindles with the wire wheel and angle grinder .... then gave them half a dozen coats of Eastwood's Diamond Clear Gloss Finish for Bare Metal.
Looks good. Only time will tell how well this stuff holds up.
Used nearly a full can on the pair, though I was outdoors so some may have been carried away by the breeze.
Russ.W. is offline
Old 02-07-2016, 01:06 AM   #3236
JMD
JMD's Avatar
Finished up mounting the braided lines on the rear axle. I love it when an idea comes together.
My build thread: http://67-72chevytrucks.com/vboard/s...96#post7439296
JMD is offline
Old 02-07-2016, 06:35 PM   #3237
Barnfind46
Barnfind46's Avatar
I finally installed my front fender that I bought two years ago.Gotta love vintage rust free GM sheet metal!Name:  035.jpg
Barnfind46 is offline
Old 02-07-2016, 10:06 PM   #3238
OregonNed
OregonNed's Avatar
Degreaser and pressure washed bed frame rails, splash pans and inner fenders prior to stripping and painting. Also cleaned up the back half of the frame for the same. Will probably paint the inner fenders body color and POR 15 and top coat everything else. Also scored a nice, clean stock diff cover to replace the rusty chrome one currently installed.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 02-08-2016, 05:33 PM   #3239
Possmguts
Possmguts's Avatar
Just hung the driver door back in place after replacing the bottom and also the top hinge along with the bottom bushings and pin... and then pulled the passenger side and replaced the upper hinge and put new bushings and pin in the lower hinge and re-hung it. They will both be coming back off a few more times, but those new hinges and the new pin kits sure make em nice and stiff again... just like new.
Old 02-08-2016, 05:47 PM   #3240
73737373
More buffing/waxing. Removed clear glass, cleaned 45 years of crud off the rubber gasket and reinstalled w/factory "Soft Ray" glass. That Hugger Orange is sooooo pretty and just pops!! Wow.
73737373 is offline
Old 02-08-2016, 08:28 PM   #3241
vidman
vidman's Avatar
Installed the B&M shifter cable and my Lokar LED shift indicator cable and sender..
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline
Old 02-08-2016, 08:32 PM   #3242
Possmguts
Possmguts's Avatar
I had to put a couple of spacers at the trans cover mount bolts to get the mount away from the lip of the cover... how was yours at that spot? I see you have an aluminum cover that offers a better flat surface..
Old 02-08-2016, 09:26 PM   #3243
vidman
vidman's Avatar
The Lokar cable mount fit ok because it ended up under the B&M cable mount. The LED sending unit did not fit at all on the trans pan, so i just mounted it on the trans crossmember. I only used about 17 inches of cable from 5' that they send with the kit..
vidman is offline
Old 02-14-2016, 12:25 AM   #3244
Synestran
Put some new tires on her finally. Long over due.
Also installed a bluetooth stereo.
Next on the list is brakes.
Synestran is offline
Old 02-17-2016, 07:41 PM   #3245
mike16
added another quart of oil
mike16 is offline
Old 02-17-2016, 11:27 PM   #3246
72.4me
I went from stock to not..should I go back?
72.4me is offline
Old 02-18-2016, 12:24 AM   #3247
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Just removing parts. I've come to the realization I can remove a TON of parts and still maintain start and stop. SSTIM suggestion and it finally clicked. Next up is the hood, for which I'll build a bench on wheels (need the room), then the grille, outer cowl, windows (gee can't wait). My mechanical experience is limited, and of course this is my first tear down, but I'm enjoying the heck out of this. Not doing the suspension by myself however, nor much of the steering. NEED SOME HELP.
Also came to the realization I "need" to lift the engine (only 40K on rebuild). Ha ha haaa.........Took long enough. Everything else is going to be removed, how hard can it possibly be to lift an engine with nothing on it for painting the frame? Exactly................Very expensive, let me tell you what I paid for NOS wiper blades and three sets of refills today. It's worth it.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline
Old 02-18-2016, 12:31 AM   #3248
71CHEVYSHORTBED402
Yes, but you already knew that.
Tony
Old 02-18-2016, 12:42 AM   #3249
Mrturner1
Now that's funny right there I don't care who you are lol
Mrturner1 is offline
Old 02-18-2016, 12:47 AM   #3250
Mrturner1
Today I touched up some paint on a few parts waiting to be installed
Closed Thread
