Old 02-04-2016, 12:35 PM   #1
Franks 72
Franks 72's Avatar
Re: What kind of seam sealer to use?
How thick are these products ? Are they runny? I would like to seal the troughs at the rear barn doors ,they are almost vertical and dont want a mess to clean up. Perhaps even some upside down work on the sil extensions. Thanks
Franks 72 is offline   Reply With Quote
Old 02-08-2016, 12:26 PM   #2
ls1nova71
ls1nova71's Avatar
I've had real good luck with Lord Fusor. http://www.autobodytoolmart.com/fuso...e-p-30952.aspx I get the neutral color which is the same color as the label, kind of tan color. It's not priced too bad either. I've had the 3m stuff just peel right back off....
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 02-09-2016, 02:15 AM   #3
Aarons72
Aarons72's Avatar
I wire wheeled most of it out and also used a screw driver/hammer combo for some chunks.
The guy at the paint store told me a few ways of using the self leveling stuff...he said for vertical stuff you can lay it down on wax paper and peel it off before you stick it on...didnt try it but i think it could work. I ended up doing my vertical seals with the self leveling...i just masked really good...laid it out really carefully...smoothed it with my finger, and then removed the tape before it dried so the edges could smooth out. Everything around my rear hatch turned out really good. Good thing at 50 bucks a tube!
Aaron Anderson
*1971 GMC Burban - Daily
*1962 Nova
Aarons72 is offline   Reply With Quote
Old 05-17-2016, 02:33 PM   #4
70STOVEBOLT
70STOVEBOLT's Avatar
Aaron,
How quickly did the self leveling stuff set up on the vertical run? Some have said you cannot use it on vertical surfaces, and some say you can. I plan on using 3M 08307 2-part sealer on mine and don't want to buy something else for the vertical runs if I don't have to.
Thanks,
Mark
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 05-17-2016, 06:26 PM   #5
Aarons72
Aarons72's Avatar
Yeah it actually turned out really nice...set up time goes fast..like 10 minutes or so. I did the drivers side, then the top, then the passenger side in three different applications. I also used tape to mask the lines...let it self level...and even used my finger a little...after a little set up I removed the tape and that little edge smoothed right out. I used the 2 part 3m stuff...about 45 bucks a tube. Turned out really nice.
Aaron Anderson
*1962 Nova
