Old 02-04-2016, 09:20 PM   #1
bmchevy1979
bmchevy1979's Avatar
05 Z71 transfer case clunk
Well I recently purchased a 05 Chevy Silverado 4x4 and i am getting ready to service the transfer case and axles on it but on the transfer case when you are shifting from high 4wd to low 4wd it makes a clunk that is fairly loud it doesn't do it any other time just when shifting from high to Low and Low to High. 4wd functions perfectly in both its just fairly loud when switching I'd like to know if it's something I should be concerned about or not the truck is pretty much stock and I plan on using it off road quite often mostly at the sand dunes and in the snow it looks to be the original fluid in the transfer case it's fairly dark compaired to the bright blue that the Autotrak ll fluid is so is it possibly that it's just gummed up from not being used very often and the fluid being old
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 02-06-2016, 10:08 PM   #2
WestButteTruck
Kung Fu Master
WestButteTruck's Avatar
Re: 05 Z71 transfer case clunk
I figure it's normal, every push button 4x4 I've owned (5) have done this going into 4 low. And typically I am on level ground, stopped, in neutral.
72 GMC SuperCustom 4x4
1972 Chevrolet Cheyenne Super 4x4
WestButteTruck is offline   Reply With Quote
Old 02-10-2016, 06:25 PM   #3
68C15
blood type; Retumbo
68C15's Avatar
I'm still trying to figure out why they put 4 low in a passenger truck.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 02-16-2016, 05:39 PM   #4
WigglesTheHoly
IT Guy/ Father/ Chevy lover
WigglesTheHoly's Avatar
68C15
Because sometimes we like to pull bushes out of the front yard....atleast that is the last time I used mine. lol
78 Chevy (Pictures) SOLD
79 Chevy LWB (pasture)
83 Chevy LWB (crushed rusted beyond repair)
02 TrailBlazer SOLD
03 VW Passat wagonSOLD
95 extended cab silveradoSOLD (still in family)
05 Crew Cab Silverado 5.3 (The Turd)
WTB: 66 El camino
Technology Specialist aspiring to be a gear head.
WigglesTheHoly is offline   Reply With Quote
Old 02-26-2016, 11:43 AM   #5
allengator
allengator's Avatar
my '04 Tahoe has done that since new.... so did the '02 before it....
Allengator
Outta the Blue
(my band - available for hire in the DFW area!)
1980 Chevy SWB Pickup (build thread)
1951 Chevy Sedan Delivery
2004 Chevy Tahoe Z71
2011 Harley Davidson Street Glide
2018 Silverado Z71 Crew Cab
allengator is offline   Reply With Quote
Old 03-26-2016, 10:29 AM   #6
kaycee
kaycee's Avatar
transfer case pump rub it will eventually crack your rear case and cause a leak or replace the back half case. A cheap easy fix for this is to get a pump rub plate to prevent this $30 its not hard at all to put in ther is another kit to use but it is $75 and a little more advanced installation. There are several videos on you tube on this procedure . If you plan on keeping the truck or 4x a lot this is a must do
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 03-28-2016, 11:03 AM   #7
WigglesTheHoly
Here is a good video on it. https://www.youtube.com/watch?v=bOyZ...nPCz4Y&index=2
02 TrailBlazer SOLD
WTB: 66 El camino
Old 04-05-2016, 02:56 AM   #8
treveiger
treveiger's Avatar
I thought the pump rub was a issue for the hds only? Does it effect all transfer cases? I'd say the clunk is normal, try it on gravel with the truck in neutral to see if it reduces the noise.
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 04-05-2016, 08:25 PM   #9
clinebarger
It affects all GMT800 trucks. For example a 1500 would have NP261-LD & a 2500 would have a NP261-HD....The only difference between the 2 is the Input Gear (27 spline vs 32 spline).
clinebarger is offline   Reply With Quote
Old 04-06-2016, 01:56 AM   #10
treveiger
treveiger's Avatar
That's good to know, thank you.
Old 04-07-2016, 10:23 PM   #11
kaycee
kaycee's Avatar
My 01 1500 had it and it has the NP 246 x-CASE
2005 FXDWG stage3
63 IMPALA 327/4L60
Old 05-21-2016, 10:06 PM   #12
richards72chevy
richards72chevy's Avatar
I have an 02 Silverado 1500 push button 4wd would it use the autotrak ll?How many quarts?Should it be changed after the truck has been driven a little bit or can it be changed cold?
richards72chevy is offline   Reply With Quote
Old 05-23-2016, 09:48 PM   #13
clinebarger
The Auto NP246 is also effected by Pump Rub.
NP246 uses 2 Quarts of Auto Trak II Fluid.
NP261 & NP263 take 2 Quarts of Dexron III ATF.
Old 05-23-2016, 09:50 PM   #14
AnotherWs6
AnotherWs6's Avatar
My 2000 with 308K miles has always done that.
1968 C-10 Suburban - Original 396/TH400
2002 Transam WS6 - M6 - Black/Black - Evil Garage Queen
2000 Silverado - DD - Small lift+Body lift+35" Duratracs+4.88's + Eaton TruTrac - Monster Truck
2010 Cadillac CTS Wagon Sport - Wife's DD and the only classy car we have.
AnotherWs6 is offline   Reply With Quote
