Old 01-11-2016, 11:21 PM   #1
Shugalou
Shugalou's Avatar
Front E Brake cable seized
Hi guys,
I'm trying to test the results of my brake overhaul but I want to make sure I have the e brake working for obvious reasons.
The eBrake pedal has be frozen in the off (all the way to the top) since I have bought the truck. It's stiff as hell and wont push down at all. I have inspected all other cables and they are fine.
Is this likely a frozen front cable or something else I could be missing?
Thanks guys
Found my dad's old truck
http://67-72chevytrucks.com/vboard/s...d.php?t=563321
Newspaper Article Publishing the quest find my dad's old truck
http://www.theglobeandmail.com/globe...ticle12494281/
Shugalou is offline   Reply With Quote
Old 01-13-2016, 02:16 PM   #2
Front Range
Front Range's Avatar
Re: Front E Brake cable seized
What year and model?
Check the pedal mechanism and look for damage / binding. You can unhook the cable at the pedal end, and check the pedal by itself for proper movement. If that looks good then grab hold of the unhooked cable and try moving it manually.
Folks that throw dirt on you aren't always trying to hurt you, and folks that pull you out of a jam aren't always trying to help you.
Front Range is offline   Reply With Quote
Old 01-13-2016, 04:19 PM   #3
Shugalou
Shugalou's Avatar
Front Range its a 78 and thanks for the advice.
I thought about that exact trouble shooting route after I sprayed a bunch of penetrating oil and let it sit overnight...I was able to get it to budge a bit more but not nearly enough...I will disconnect to ensure the pedal is working correctly.
Old 02-05-2016, 09:58 AM   #4
Shugalou
Shugalou's Avatar
So it turns out this was an easy one created by lack of experience.
I had tightened the cable too much after doing the rear brakes...I loosened it off a lot and now operates correctly. I think I will test out the rear drum clearances again before taking it out on the road to do the self adjust test...feel like I'm almost there
Old 02-05-2016, 11:32 AM   #5
Front Range
"The eBrake pedal has be frozen in the off (all the way to the top) since I have bought the truck."
That's the part that threw me, sounded like you bought it that way. Glad you got it figured out.
Old 02-05-2016, 11:44 AM   #6
Shugalou
Shugalou's Avatar
Yeah I was mistaken, I never had a chance to test it since I bought the truck and just ASSumed it was another thing that was needing attention.
Looking back I should have tested it before I even tore into the brake system overhaul.
